Im happy to try and search this if someone can tell me how. Im trying to figure out the best options and the best lift for my trail boss. Im thinking I would like to end up with 6"of total lift. When I look at lifts its confusing with the trail boss. Any help would be much appreciated.
As far as i can tell there isnt a 6" lift out for the trail boss right now. You'd need to get a 4" lift and that would be the equivalent of a 6" lift on a standard silverado. If you're willing to hold off for a bit ready lift has an 8" lift for the silverado id bet would make it over to the trailboss soon. That would give you 6" of lift over what you have now.
Thanks bud!  I am willing to hold off.....in fact I woke up this morning thinking I need to just cool my jets a little. I'm going to just try and level the truck for now and enjoy it.  I was looking a kit from ready lift to do just that but I had some questions about it as well in another thread. For the record I was thinking 6 total....so the 4" with my already 2" would be what I was looking for.  Thanks again!
If you go the route of a leveling kit make sure you get one that comes with new control arms. The factory ball joints aren't holding up. In the process of changing mine now.
scrap out shocks and block and throw std 6" lift on there......remove the shocks and its standard silverado, has lifted strut in front to get the height......you can just get whole new kit with shocks, no waiting.....sell stock kit on ebay for someone who wants to lift their standard truck....though they wont have longer cv axles, but they arent crazy expensive....
combing 2 lifts kinda seems idk.....a bit mickey mouse....just a thought anyway
Edited by Dunn
I've often wondered this myself.  I don't understand why all the lift companies state "not for TB/AT4".  Isn't the truck returned to a "standard" non-TB/AT4 when the front struts and rear blocks are removed?  The only difference would then be the longer CVs left in the truck.  So, why can't I just order and install any lift kit then?
That's the companys covering their butts for insurance purposes. You really just need standard length front struts to put on with the kit unless I'm missing something.
Having longer cv axles would be a good thing not a bad thing for lifted truck
But yeah take out stock TB lift you have stock silverado platform to work off of.......most good lift kits will give you new shocks, UCAs, diff spacers and block anyways....not cheapest route but certainly a better one i would think for life of truck, ride quality and performance..
Think it may be company's that are combining their spacer kits to the standard/TB existing kits is the issue.....thats why some say not for TB if its meant for standard silvy (using existing suspension)
a complete kit shouldn't matter cuz your replacing everything....
Edited by Dunn
What leveling kit did you end up going with?
It's a Zone 1.75" kit with uppercontol arms. It's coming in Wednesday. It uses preload spacers and a small puck spacer on top of the strut to keep from over extending.
You're all over it! I was researching this this weekend....probably as you were writing your post lol. I will end up installing a 6" lift (maybe even 8") for a non trail boss. Will sell everything off my truck except my trail boss CV's.
So on the lift kit ....I want to take the time to have a complete plan as far as lift company I want to use. Shock company I want to use. Custom wheels and  tires I want. I want all of this in the garage and ready to install in one weekend. This is easily $10k and need to put in the time and research so there are no expensive mistakes.
Because the rake in the truck is bugging me.... For now Im just going to level the truck with a kit that includes upper control arms.
I had a thread started about RC 2" level/lift kit and RC says if you install their kit you should not use auto 4wd it could damage your truck.
They also say the same thing about their 1.75" leveling kit....dont use auto 4wd.
ReadyLIFT | 2019-2021 GMC AT4 and Chevy Trail Boss - 1.75'' Leveling Kit
So I'm wondering if this type of damage is possible with RC is it possible with all the brands of leveling kits? What would make the other kits any better?
It's an issue with the big leveling kits and actual lift kits. It's only an issue with auto 4wd. Something about vibrations
That makes sense......so I assume your not planning on using auto 4wd?
Edited by 21trailboss
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
