Over the weekend I finally got around to installing my S&B cold air intake on my 2017 Silverado 5.3.  Since I finished it up late last night I never took it for a drive.  This morning I tried to start my truck with the remote start and it didn't work (I'm guessing due to the check engine light being on).  When I started my truck the engine light was on.  I do remember installing the air flow sensor in the same direction.  Anyone have any ideas as to why the light would be on?
Chris
Ok, I disconnected the negative battery lead and let the computer clear any learned programming.  I then let the truck run for 15 minutes to learn the new CAI.  The light is off for now.  I'll keep you posted if it goes back on.
Edited by SoonerTA
I installed an S&B setup on my F250 6.7L. It said to keep the battery disconnected for at least 2 hours or you can get a check engine light. To play it safe I waited about 3 hours. Never had an issue.
I put a S&B on my uncle's 5.3, no issues. Ill be ordering one for my 6.2 when they get back in stock.
  • 3 months later...
Ran into the same issue on mine, although I think it was my fault. I cleaned the MAF before reinstalling it but don't think I gave it enough time to dry so I ended up having to replace it. After that though, everything was fine and ran smooth.
  • 11 months later...
I installed the kit today, did the battery disconnect as they stated. Not quite sure it was a full 2 hours, but I reconnected everything after I finished and started it up. It ran fine and after a few minutes stated idling 1423889E-3682-43AC-9611-BCCE3B15013D.thumb.jpeg.db7755a880b09419e0d2c92bd914681d.jpegerratically and threw a check engine light. The code was for the MAF. I disconnected the battery again and will wait 3 hours and try again. If that doesn’t work, I’ll replace the sensor. I guess those things are delicate, but I was careful with it. Also tightened up all the clamps just in case it’s a intake leak past the sensor.
Edited by Mosesc789
either forgot to reconnect the maf sensor or you also might have air leaking past the maf too
I also recommend removing the hoses going into the CAI tube into the throttle body, plug em up, and run uni filters for the valve covers, since thats also unmetered air
Years ago I bent one of the MAF sensor pins when I reconnected the wiring harness to the terminal. Idle was terrible and my fans wouldn’t stop running. Might be something to check.
  • 6 months later...
Edited by Swaveyalexis
Did u get it to work ?
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
