I have 2016 with 5.3. I’ve noticed even driving highway speed for extended time my temp gauge will not stay at 210 on the gauge. Any slow down for stop light or other light city driving the temp will drop some on the gauge. I’m assuming I should be maintaining the normal operation temp no matter ambient temp? Anyone else run into this thinking it’s a thermostat stuck in between.
Time to replace it's all in 1.  Housing included 35-40.00 bucks
Yes, that means seals starts to leak/crack allowing the fluid to circulate and not being fully closed.
Just replace it with a new one if that bothers you.
How many miles do you have on this motor?
1 minute ago, Lspoo19 said:
Just under 42k
It's not that a thermostat can't fail in such a short time but for the factory one this is unusually short. How much short of straight up is the needle? Got a photo?
That's about where mine runs all the time but I'm running a 170 F thermostat so that is low. What part of the country to you live in? Mine would get that low on really cold days with the factory 207 F stat in it.
On the thermostat housing is a small bleed line that goes back to the radiator catch tank. This is a minimum flow bypass around the thermostat to 1.) provide enough flow to keep the pump happy. 2.) Get hot water to the thermostat so it operates correctly as the thermostat itself does not have a bleed or 'jiggle pin" for this purpose as the Gen 1 motors had. IF you live an an area where it gets really cold then it is possible that this alone will keep the motor cool under light loads...non-highway.
Of course it still could be the stat seal as was suggested earlier. They are not the hard to change.
In the Midwest been negative temps all week. I’ve still noticed it when it’s 60 out. I’m sure the bypass is what’s causing the cooler temp
Then change the thermostat if you're sure. You know your truck better than anyone else, right?
:cheers:
On 2/12/2021 at 1:21 PM, JONBLARC7 said:
Anybody know the part number for the colder CTSV or ZR1 thermostat.
Engine Coolant Thermostat
Part Number:  12T020E
Product Notes:
All; Temperature 194F; Incls housing, thermostat, & seal; OEM Recommended Temp; Std
Per Vehicle: 1; Years: 2016-2017
Edited by Grumpy Bear
Not hard to change, their are some youtube videos out there.
I didn't drain the radiator, just took off the hoses and changed the assembly, and topped off the coolant. Mine did the same thing at 50k miles. 10mm socket and slip joint pliers, and common screwdriver for clamps
Product Notes:
The above number is the ACDELCO GOLD/PROFESSIONAL (lower priced, lower quality)
The below number is the ACDELCO GM ORIGINAL EQUIPMENT
Engine Coolant Thermostat Housing
Part Number:  15-11113
Product Notes:
All; V, VIN: 6, Eng Code: LT4*
Per Vehicle: 1; Years: 2017-2017
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 784 Guests (See full list)
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
