The battery has been running down on my 2003 GMC Sierra 1500 if it isn't started / driven in ~weeks time. Using a multi-meter between the Neg Post & Cable, I was able to verify an initial current draw of ~2 amps, then it drops off to ~1/2 amp. But then it pulses between 1/2 amp & a negligible draw. Pulling fuses, I narrowed it down to the DIC (Driver Information) circuit (aka Gauge Cluster). If that fuse is pulled, it stops the drain.  Unfortunately, that fuse is necessary for the gauges to function, so it can't be left out.  Also, I did notice the Odometer reading pulsing on & off occasionally when I was checking the current draw.
This isn't my Daily Driver anymore, so it sits for 1-2 weeks between being driven.  Several months ago, I noticed the Odometer display would get stuck cycling between the various languages. I could usually get it to settle down, but not always. Can't remember if this started before or after I experienced the dead battery issue. Finally decided the old battery needed replaced & I bought a replacement. It stayed charged for a few weeks before I went out one day to drive the truck & it was dead again. Jump it off & it runs fine.
Can the gauge cluster be easily repaired? Can I swap in another cluster from a roughly same year range truck? I know the mileage would be off, but can it be reprogrammed to match the old cluster?
you could do that if you think that is where the PD is. Or since you dont use the truck anymore, go and buy your self a battery shut off for 13 dollars and just reset your clock when you are using it. https://www.amazon.com/Side-Battery-Master-Disconnect-Switch/dp/B001N72FES and the 2nd part of your question the answer is no, you cant change the hours or mileage as it is stored in the cluster,  otherwise people would just shave off 100k before the sale.
Edited by Sharpz
I wouldn't bother with swapping the DIC in a truck that old. I would either buy a battery shutoff or add a battery tender and keep it plugged in while the truck is unused.
I have repaired my own cluster for the "dim shifter"... its not hard if you are familiar with soldering.... the whole took about 30mins including the time it took to remove the cluster and reinstall it... hour tops if you include the time waiting for the soldering iron to heat up and putting stuff away
Presuming you can locate the cracked solder joints for this power problem it should be pretty easy to repair.
with that said, I think that $200 is probably fair for a complete rebuild including new motors... but like the other guys said, not sure its worth that sort of money for a truck so old... but a worthwhile DIY project.
What is happening is there is silver migration on the circuit board from the soft silver solder they used when assembling the circuit boards. The soft solder can cause a short within the tiny holes on the board. It can cause the DIC to display solid squares or goofy characters or a parasitic draw which will drain the battery over a few days. Have it rebuilt with the lifetime warranty. GM Gauge Repairs does complete rebuilds for 125 to 140. https://www.gmgaugerepair.com/chevrolet-instrument-cluster-repair/digital-gauge-cluster/
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
