Has anyone purchased the TPMS valve stems to add to your boat trailer? I have them on my 5th wheel and they work good and are tied into the truck system. I am thinking that since they are sealed inside the tire that water wouldn’t be an issue. Anyone else have experience? Also any idea what size diameter valve stems they are? Thanks.
Tagging in for future info. I have them, but don’t have them installed yet. You’re correct they won’t get wet because they’re in the tire.
good question. I have them and was going to get them installed in the boat trailer wheels. Didn't even think about water. I'm sure they would be fine though as long as there are caps on them
4 minutes ago, Mercracing said:
Guys, it’s inside a pressurized tire. Water can’t get in unless you have a flat.
Exactly what I was thinking. Have you ever been worried about your truck TPMS sensors when you are backing into the ramp or going through a deep puddle?
I was more worried about corrosion as the factory TPMS have a metal body and stem. I don’t usually back my truck tires all the way under salt water but the trailer would be.
You’re not Parking under salt water. Shouldn’t be any different then us driving around during the winter. Rinse it off when you can and you should be good.
Ok same subject...different question..
If cost is not an issue I was wondering how the truck would handle if I put a TPMS on the spare tire. I would have 5 tires which is an odd number. The truck wants you to put in the number of axles on trailer so if I say 3 axles it would show one side with pressure and the other with 0. Do you think it would give a constant alarm of no signal every time I start up?
Wait...they don't have a tpm in the spare? My 2006 Toyota has one in the spare...
I don’t think so. I’m not positive about the trucks, but one of my suburbans had a flat and I had an alert every time I started it for two days till I got the tire fixed.
Did you check with GM to see how many sensors the factory unit will store? I only ask as my old Tundra only stored 4 so GM might only store 8.
Stores 4 for the truck..
With the trailering app, each Trailer can have up to 6.
Optional package of trailer sensors with factory order is 4 sensors.  Additional sensors can be ordered thru accessories.
Trailer sensors include temperature, Truck sensors do not.
Trailering app will keeps a bunch of other info, including fuel economy numbers, brake controller settings and maintenance reminders settings for each trailer. It also has provision for 'guest' trailer.
There can be up to five trailer profiles, so that could be a total of 30 trailer sensors.
Trailer profiles will be listed in the order of the most frequently used.
There can also be a 'guest' profile.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
