My front differential is looking like it will need a rebuild sooner rather than later. I've done some preliminary research and it appears that there's an Eaton Truetrac (912A557) compatible with this application. Keeping in mind that I live in Alaska and the roads are covered in snow/ice for about half the year, is it worth the trouble?
  • I live in the south west and get virtually no snow or ice, but when something needs changed it needs changed.  You can google search easy enough the advantages of what you are looking for.  What it would come down to me is what I am willing to do for my truck.  If money or time isnt an issue, why not?  I liken the type of question to do I run stock lift or put in a 2 ".  It really is about preference and in most cases the performance benefits are not so great as to justify the means, but sometimes looks better.
Nope, your front differential is an 8.25" and there is no limited slip or locker made for them since I last looked a few years ago.  Most writin' says the case cannot take the strain of one.
Well bummer. Thanks though
James stole my thunder. When I was installing a air-actuated Ox Locker in the rear end of my '07 Silverado, I looked into getting one later on down the road for the front. As I looked, I noticed nothing was available - not from Ox, or anyone else that I could find. There were listings for EVERYTHING but. The general consensus out there on the net is that these are the weakest geartrain assemblies ever produced.
I had thought this only pertained to 2007 and newer trucks, but I guess not. That sucks.
  • 3 years later...
Alright need some advice here please.. i had ordered the wrong diff for my 1500 Silverado non HD which i ended up ordering instead one for an HD.but the gear ratio is the same for the front of my truck and it's 4x4 will i be able to use is still or do i need to get one for a non hd.. i heard from a friend it would work but would like an second opinion and will i run into any problems in the future if it turns out i may use it?? I do know the housing is a slite bigger.. so that being said what should I do.. 🙏🙏
You need to get a regular half ton diff.
Not only are the mounting points different on a half ton frame compared to a 3/4 or 1 ton frame but the driveshafts are different sizes and the stub shafts are different too for the bigger axles.
    btm
    btm
  • Who's Online   5 Members, 1 Anonymous, 1,333 Guests (See full list)
