For those with the multipro tailgate, has anyone sprayed their tailgate? I like to err on the side of engineers being smart and doing things for a reason...trying to understand why it isn’t sprayed and just a plastic cover protector
that plastic cover is the tailgate am pretty sure, not sure there is sheet metal underneath.......my 2500 didnt have plastic it just had sheet metal......and believe my 19 RST just had the plastic cover with no sheet metal under it.....am not 100% positive but remember either reading it or hearing it......could be 100% BS of course
which is actually nice cuz replacements arent expensive and can be eaily done if it gets messed up and mine surely will
Edited by Dunn
When I had my bed sprayed with linex they told me there was only a skeleton under the plastic and did not recommend spraying the tailgate
Edited by Greyhound6.2
Mine was sprayed with a bed liner from the factory. (Bed and multipro tailgate)
You should check your tailgate again, it's a plastic cover, not bedlined. It matches the look, but it is a plastic cover. I have the factory bedliner and multi flex tailgate I ordered from the factory.
You can probably use the DIY roll on or spray on bed liner. The heat the pros use would more than likely damage the plastic
    C. Hart
    C. Hart
  • Who's Online   2 Members, 0 Anonymous, 447 Guests (See full list)
