I have a 2012 GMC Sierra 1500 5.3L V8. Unfortunately, I was attempting to go through the firewall and hit several wires and it has become a huge mess. Long story short, after mechanic bills and other issues, I have to replace the wiring harness. My question is this, all of the wiring harnesses I see only go up to the fuse box. I need the wiring that goes through the firewall and up through the dash. Is this called something different or am I just not seeing it when I am trying to find an engine wiring harness? I hope I'm explaining this correctly, if not, please feel free to comment. Thanks so much!!
you can search here, but if you are looking for the complete wiring harness for all of your dash, that is a lot of wires, you might try a pull a part place.  Also you can search here for what you are looking for specificly.  I didnt know your details so just chose one. https://www.wholesalegmpartsonline.com/cars/Chevrolet/2012/Silverado--CREW-CAB-LTZ/Wiring-Harness/Silverado--CREW-CAB-LTZ-parts.html
That sounds like quite the ordeal. Without seeing it, I would call it the body harness. How many wires were severed that a competent mechanic can't repair a few broken wires? If they can't do that, no way I would let them attempt to tear the whole dash apart and replace a body harness.
check your dealership ( parts man ) , get a print out of what you need . Buy New or repair your self ?? good luck.
There are several burnt and melted wires at the site where the wires insert at the firewall. If there are more wires affected from shorts, I have no idea. I have a towing, stabilitrak, and airbag light on. I took it to a mechanic and after almost $700, it now has a battery drain and nothing is fixed.
yeah that is a huge issue then. You need to completely remove all of the dash, and probably the duct system to access all of these wires to remove and feed in the harness's that you are speaking about.  A heads up, if you were to just change the heater core and no wires, I believe the book says 8 hrs, so don't expect this to be a  few hour project.  Again what I would suggest is getting the wires from a pull a part, but first remove the dash, and anything else preventing you from seeing the wires completely before just replacing blindly.  Make sure you disconnect your battery too, leaving it hooked can cause a fire, or even more damage even if the truck isnt running.
Is there any way to get to these wires to repair them other than pulling everything out (pulling the wiring in through the firewall into the dash to get a good look at it)? When I attempted repair prior, I pulled it through to the hood and really couldn't get at what I was trying to repair. I'm just wondering if this might be worth a shot before doing a complete dash teardown.
I told them what was wrong and they replaced the steering wheel sensor, with me telling them what the problem was. They even brought in a "specialist" and he couldn't figure it out. I saved up money to take it to the shop only for it to come out worse. The guy told me literally to put a picture up over the warning lights and not worry about it! I now have this serious battery drain that I didn't have before so I don't know what they have done. I'm not made of money and I'm disabled so it's very difficult for me to get in and out of places like under a dash. I'm just so frustrated with the whole thing! I'm the most irritated at myself for cutting the wires in the first place!
That sounds like it goes way beyond replacing just a couple of wires. By the time you've figured out how many and what components actually got torched you would probably be much farther ahead just buying something else. There have been late model vehicles incorrectly "jump started" and were deemed a total loss afterwards.
Best of luck.
no there sure isnt.  Here is the problem and why you have no choice but to strip the dash to inspect all of your wires. You don't know what wires were affected and which ones were not. Just because you replace one or two doesnt mean there isnt 20 more that are damaged.  Sometimes one breeds the other, and wires can burn long amounts of coating/insulation, and can get so hot they can melt other wires too.  You are very lucky, that 1) your truck didnt catch fire, and 2) that it didnt fry major electrical components of your truck.  Disconnect the battery as I said, Park this one, and remove the dash and probably the duct system. It isnt easy by any means, but that is where you are at.  It doesnt cost you any money to remove the dash but will be extremely costly every time you start that pig up, and melt more wires, fry your brain, bcm, ecm, etc.  Removing the dash will allow you to visually  inspect all of your harness wires, and who knows,  maybe you can just splice in a few tape them up and be done, but at this point probably not.  Its hard to image what one hole drilled in the wrong spot can do, but here you are.  Not to kick you why you are down either, but cutting short cuts or at least trying to is what got you here in the first, place, dont cut corners with this. Make sure you fix it right, or you might be plagued with problems down the road.
I really appreciate your honesty and completely understand/agree with what you are saying. I am so frustrated with myself for this entire situation. So many things I wish I would have done different. I do have a friend who has offered help and she has over 10 years in auto restoration. I'm thinking this will be my spring/summer project. Not exactly how I wanted to spend my summer, but I do love my truck. As far as parking her for a while, are there any precautions I need to do with the gas and tires? I have pretty expensive tires and sure don't want to lose those. The reason I ask is because I am disabled and it takes me a lot longer to do things than most as my back doesn't move very well. So this could actually take me awhile to complete.
you could jack stand/block your truck up, and keep the tires in the garage, if that isnt an option,  contractor bags over them and taped will keep the sun from messing with them too bad. Jack it up once a month and rotate 90 degrees, and they will be fine. Fuel stabilizer is about all you can do for the fuel, hopefully you use no ethanol.  Something to do, if possible, is make good labels for what came from where and what order, filming your friend take the dash out, would be helpful putting it back together.  It isnt horrible to be honest, but time consuming.  There are plenty of videos out there on how to remove the dash, and what you need to do that.  Just make sure y'all are  thorough,  Make this a one time deal.  Good luck, and please be sure to post the updates, and questions, there are plenty of people that can help answer your questions.
@Sharpz
You really have given me some great advice and I can't thank you enough for your honesty and helpfulness. I will definitely keep things up to date and do it the right way this time! Thanks again!!
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
