On 3/27/2021 at 7:45 AM, silveradosid said:
would really like to know what they find, i have the same problem but it is at 1600 rpms at any speed
Dealer called and said it was the adaptive exhaust valve. Apparently it can fail and make that vibration. To fix it they would replace the exhaust and take $1000. I said nah and I'll figure something else out. Maybe time for a cat back.
1 hour ago, silveradosid said:
i use a range device and have had the valve  bolted open, so i guess i will have to find what is causing it
yeah thats what they told me but I'm still skeptical. when i go to pick it up ill ask how they test it and if i can get it to go away by doing exactly what you did.
well i got some more news. the radiator was leaking so they replaced that. they lubed up the adaptive valve and it was doing the wash board vibration bad and it was determined it has a failing torque converter.
first time ive ever had a warranty pay for its self. all i have to pay for is the fluid and filter change.
20 hours ago, silveradosid said:
well i glad they actually found the problem and are going to fix it, what did they charge to do the rad
yep all will be fixed the rad is also covered. for all of it i only have to pay $280 for fluid and filter change in the trans. it should be done tomorrow and i will ask them what this would have all cost me out of pocket without warranty.
Edited by djw88
Delete the t-stat in the transmission and get a tranny cooler. TCC is known to fail in these around 60k along with the radiator.
Edited by ic3man5
$1930 in labor $1213 in parts and in the end i had to pay $312 out of pocket.
just the radiator replacement would have cost $1323 total
On 4/6/2021 at 6:45 AM, silveradosid said:
did you have any fluctuations in the rpms or just the vibrations
not really. maybe slight variations but mostly a washboard vibration feel
what the dealer did was hook up a scan tool while driving and when the truck had the vibrations he was able to de activate the TCC and the vibration went away. so they knew it was a failing torque converter.
    • Part is $233.87.     Not sure where $900 came from?
    • Looks like you have it figured out. Did you run a sensor into the rear diff housing?    What sort of diff temp swings would you see towing or not? I have wondered how hot it can get
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
