So I have put this off for a little while and ready to fix it but when I was working on my leveling kit and putting everything back together I used an impact wrench like a dummy to fasten the 10mm bolts down that hold the brackets for mounting the brake line and speed sensor line and broke off one on the back of the knuckle.  wondering if anyone else has had this happened and were you able to get it out?   Can i drill it out with a small drill bit or an extractor Possibly?  Hoping all I have to do is take the wheel off and leave everything else hooked up and run the bit or whatever in there to get it out.
If you don't posess a lot of experience extracting broken fasteners you should take the vehicle somewhere before you make the situation worse.
I'm hesitant to ask but did you use a torque wrench during reassembly or just impact all the things?
Edited by It's Tim
I don't have much experience extracting bolts.  I asked because I was hoping may be someone had done something similar which I figured would be a long shot.   I dont know a shop that specializes in bolt extracting so should I take it to a regular shop that does tires and brakes?
i agree take it to someone.. I install a lot of commercial  door hardware . Small bolts get broken off and with extraction you have ONE GOOD Shot. You have to drill it out just right use the exact proper extractor and  HOPE!!   90% Of the time they break loose and come out. Being a new Truck is on your side.. But if extraction fails  its tap and die time.
ohh and by all means use a high quality extractor with a t- bar or wrench NO  POWER TOOLS..
Just  wear gloves if you attempt this. so you do not break a finger nail. i hate when that happens
if you take it to someone it should be a high end auto shop not a tire and lube kinda place .
Edited by ericarenee
hard to find a high end shop around here.  I got to thinking about it this morning and to do it right the whole spindle/knuckle might need to come off :( because its on the backside of it and not sure you could see what you were doing but possibly if someone had it on a lift they could do it.
    Daniel422
    Daniel422
  • Who's Online   5 Members, 1 Anonymous, 1,836 Guests (See full list)
    • It is a company truck. Not under warranty. Both companies I’m involved with usually buy trucks that are discounted when looking. Except what the owners drive. Being retired and minority owner. I don’t drive a company truck. If they have the new GM gas engine it would be in a service truck.
    • Update!   Had the dealer look at the issue. First tech says no problem?? I said there was no voltage on the brake terminal on the 7 pin connector! He said he did not know what pin I was talking about. So they bring out a seasoned tech and I explain to him. He attaches a VOM and has me push the brake, and sees no voltage!!    Tom, the seasoned guy says lets go back to my service bay and look closer. We discover thru his on line system that the controller is a "smart controller" as it needs to detect a trailer connected before the brake voltage is allowed to the 7 pin connector!!! He also showed me a GM bulletin stating some trailers with LED lights have such low resistance the controller wont recognize them!!! I was thinking WTF, but thanked him for bringing me back into the service bay and explaining this all to me. He also plugged in a trailer simulator and it showed the brake controller was indeed working.   After my dealership visit I hooked up to an older camper with standard 1157 lights and the truck did connect and the electric brakes worked great!    Not to sure what I have to do with the equipment trailer with LED lights, I cant tow it with no brakes.   Why did something so simple for many years have to get so complicated!
    • Do find out as that would be interesting if they have been using any L8T engines or for that matter have been running any of the Ford gas 7.3 to see how they have been panning out.    I assume your nephews engine replacement was on his dime as the regular warranty would have long past unless he had some form of extended warranty that covered such events. That shows though and may depend on the year of the build that failures are occurring with the valve train well beyond the warranty distance and more than likely so will others have that sneak up on them.
    • I realize this is an old post and its probably been talked about since then on this forum and I may have mentioned it myself but the Chev multi flex tailgate on the HD trucks are all aluminum so there is that one item that I am aware of on a current GM HD truck that is aluminum but if its the standard tailgate then its still a steel unit as far as I am aware to current 2026 model year.
    • I am surprised it didn't pop back up some just in time for the end of school/summer holidays and July 4th time period. Here in Alberta it hit its low coming off the high back a week before the end of June or so and has been creeping back up some and would equate roughly to around 20 cents per gallon increase. Of course there are various factors and one is the games they typically play with wanting to capture that holiday vehicle movement but also our government directly causing our Canadian dollar to drop ( a polite way of explaining the real picture ) causing our prices to go up rather than continue down like it should have, and even though we are sitting on the crude.
