Thanks for the update. I'm in the same boat as you. I will wait to see if anything new transpires from the trip to the GM dealer.
  • 5 months later...
The way this add on module was explained to me is the 2021 and 2022 (possibly 2020) require an upgraded radio when choosing the trailer app for TPMS. The radio RPO codes for the trucks with the trailer TPMS is different than the ones without. My 2021 Silverado 3500HD was ordered without the trailer TPMS package and I had wanted to upgrade since the TPMS system that came on my fifth wheel is an absolute dumpster fire. The answer I got from my contact was that part of the approx $400 cost of the trailer TPMS was for the upgraded radio. GM has been changing their electronics architecture regularly so the 2019 might be possible to upgrade by adding the module but for sure the 21 and 22 are not.
I just purchased a 2022 Silverado ZR2 Refresh with 5K miles. I was wondering if it supports trailer tire pressure sensors?
It has the UET Trailer App. It doesn't have the PTT option on the window sticker or the build sheet. I was wondering if PTT is just to add sensors to the truck order?
I looked behind the license plate and there is what appears to be a TPMS module there. Unless it for the truck itself? Other threads have suggested the module behind the license plate is for trailer tire pressure sensors. The trailer app on the Informant screen doesn't show anything for learning trailer tire pressure sensors. I don't have sensors as yet as I wasn't sure if my ZR2 would support them.
I have not connected to my trailer as yet to see if that makes a difference. Its small and only has a 4 pin plug. I ordered a 7 to 4 pin adapter. I only have a 7 pin on the ZR2. The other connections on the bumper with the 7 pin are for the two TRG trailer camera provisions.
I should have the 4 pin adapter in a few days to find out but I thought I would ask here.
Edited by cef2lion
Typing corrections
Just now, SkipHit said:
I know this has been here awhile, however, I found that on my 19+ Silverado with the Trailer TPMS harness it has only the #3 and #4 pins installed. I have to install power and ground terminals for the module to be seen by the BCM. I've found that this dealer install option has their tech installing these terminals and functions properly once completed. Hope this helps i've added the wiring diagram for anyone who needs it.
  • 5 months later...
I have a 2020 Silverado Z71 LT. I purchased / installed the TPMS sensors and the module, and wired the positive and ground wires. I still only get the "test trailer lights". That's with the trailer hooked up and the TPMS sensor activated using the tool from Amazon. The only thing left is the radio. Does anyone know what the correct part number is for the radio? Or is there something else that I should try first?
I have a 2022 Sierra 1500 AT4 3.0 and it has the module installed behind the license plate from the factory, truck did not come with the extra sensors for a trailer though.
In my trailering app I don’t see anything at all for TPMS.  For those of you that are able to see trailer TPMS do you always have something visible in your trailer app, or only when connected to a trailer that has TPMS installed?
Curious if I added TPMS sensors to my trailer if I would be good to go or not.  I see many appear to need a new radio but it seems odd to me that I would need that if the module is already installed on the truck when it was built.
Edited by Drew6424
Added photo
  • 7 months later...
On 3/20/2025 at 10:26 AM, A Jackson said:
Anyone have luck adding the TTPMS module?
Yes, i just had to add power and a ground wire. No programming needed bcm recognized it right away. I did buy an OE connector with all 4 wires from Amazon for ease of install. Look at my above post for wiring. And I bought my module using myChevrolet points, it’s only $100 for the module.
Good luck
Edited by SkipHit
Good luck
This post above gives me hope!
I have a 2020 1500 and purchased the module. Got all excited - hooked it up and blam!!!! Got the same old test lights when entering trailer mode. No expanded menuing…. So begs the question. I see the wiring diagram - can’t for the life of me figure where or how to install the extra power or ground. Any pics or extra info on that maybe?
and then - the connector that you got from Amazon. What was that for specifically? Any link to that? Or was that a nice to have not a need to have.
Hoping that this extra wire attempt gets this going for us - am anxious to be a little safer riding the camper and knowing how those wheels are doing!
https://a.co/d/j1N1uCl
here is the link to the OE 4 wire pigtail I ordered. Hope this helps. I just placed the missing wires into the original pigtail and color coded them then traced the power line and wired in a ground. I didn’t want to cut any original wires. They just clicked right in.
Edited by SkipHit
Success or not making TTPMS work when it wasn't factory installed possibly depends on if the trim level had it as an available option.
Even in 2025 model year TTPMS is not available on all trims.
Trying to add this to my 2021 Silverado, where did you tap in to get the 12volts and ground?
I tracked power to the trailer module above the spare
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
