I know this has been covered in many other threads,  and that the truck pulses the lights every several seconds as part of the trailer security feature. Mine does that too. But it will then start to flash much more rapidly. Like multiple times per second. See attached video. Anyone else have this happen and know what causes it?
Edited by bamorris2
It's flashing your clearance lights and taillights. I would guess a wiring issue? Have you tried a test light on the back of your truck to make sure that it's right?
If so, than it's on the trailer side of things.
Sent from my Pixel 4 XL using Tapatalk
Yes all of the power sources are getting proper power. It only does this when the truck is parked and off. It stops just by unlocking the truck or starting it up. All of the trailer lights work perfectly otherwise.
Ohh..... Beyond my experience.
I'll be watching to see what you find, hopefully others will have the answer!
Any updates, was the tech bulletins from rst helpful? Just curious.
Mine will flash rapidly several times per second if I lock my truck by pressing the button on the outside of the door handle. However it will act completely normal if I use the key fob to lock the truck. Not sure of why it acts differently but it is 100% repetable like that. Only the brake/tail lights flash rapidly
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
