6 minutes ago, Philbert said:
You should hear the territory MT tires on the AT4 carbonpro. I wonder if I replace just the muffler with a borla attak and keep everything else on the exhaust stock,  will I hear it over the tires?
Same tires on the Trailboss.  So, the tires should "hide" the drone :)
Edited by Rob Mugs
10 hours ago, Rob Mugs said:
Just put some Duratracs on.. you won't hear it over the drone of the tires :)
Man... I hav run the Dura's for YEARS.. on 5 vehicles and well over 700K miles... now that Goodyear went to a (2) ply these tires SUCK!  Drone like crazy... it is entirely a different tire.
On 3/16/2021 at 3:49 PM, Rob Mugs said:
I am only aware of it as my buddy has a Trailboss himself and has a 40 series.  Says he can't hear the exhaust over the tires and I'd be inclined to believe it.  They are not quiet :)
Finally had a Borla atak muffler installed today.  FLAP REMOVED. It definitely is louder and sounds like a v8 and magically the annoying rattle is gone. One of the advantages of removing the flapper.
On 3/16/2021 at 11:34 AM, It's Tim said:
Obviously, really bad info.
If for some reason the engine were to run lean and eat a pistion or 2 that would be on the OPs dime.
How would it cause the vehicle to run lean if the pipe is after the sensors?
On 3/16/2021 at 12:41 PM, Claudio Salgado said:
Would a flow master muffler and resonator delete make engine run leaner?
Mechanically, I can not see how it could cause a vehicle to run lean as there are no sensors after the muffler.
