On 4/30/2021 at 6:06 PM, DeePa said:
Agreed 100 percent. I also think the trans tuning is a big part of it. You don’t hear about the 14s and 15s having this issue.
You said that the 14s and 15s don't have the torque converter clutch issue? Maybe I'm not so lucky then? Cause my transmission had a little film of alu dust in it. My truck is build in december 2013 but the transmission is build in 2015 (I think).
What I'm meaning to say is: do I need to change the transmission software or is it ok to leave it like it is now?
It drives like new now but I want to run the transmission way past 100000mls without rebuilding it every few years.
To me having the transmission tuned is a good thing and will make it last.  If you firm upt he shifts that increases the life of the transmission by reducing heat and wear.  My 2002 had nice firm shifts and I had it tuned from 10k miles on and it was in great shape at 200k when I sold it.  Speaking of which, I have the new owners contact info. I might contact him to see how it's going.  He purchased it specifically to tow his camper.  This was August of last year.  I would contact Black Bear Performance about tuning it.  To me well worth the money.
So all the 6L80 transmissions have the bad torque converter clutch problem? And not just the early ones? But why didn't anyone in the aftermarket car parts business have developed a better torque converter for the 6L80? The company who did could earn millions of dollars🤑😇. I don't hear that dodge or ford have such major transmission design flaws.
I always been a chevy truck fan but isn't gm making it very hard for us not to buy a different brand of truck?🤔
JMBX...that's the converter with issues. https://www.sonnax.com/tech_resources/845-6l80-6l90-transmission-tech-advisory-consider-an-updated-converter-in-your-next-rebuild
Somebody did do something about it. SONNAX.
People have an issue. Converter torches the transmission. Dealership will only use OEM parts in a warranty job. So Joe Owner gets to repeat the mistake because not paying now seems better to him that paying fully later. It's a head scratcher.
Does sonnax sell those modified converters or must I buy a sonnax tcc kit and take it to a transmission company together with my bad torque converter? Or do you know other companies who sell "improved torque converters" for my 6L80?
You have a PM
1 hour ago, newdude said:
I PM'd him an email address to a private party that 'may' know something. Not mine. Just respecting the guys privacy.
Thanks grumpy bear for the pm. I'll keep that tip in mind.
You said that the problem is the jmbx torque converter. I put a heavy duty jmbx in my transmission(HDB85JMBX).  Are the hd versions better or just as bad? Perhaps the heavy duty version usses a different torque converter clutch?
This is what I'm going to do. Modify the transmission software and then drive it for 8000mls. Then drain the oil and see if there's debris or alu dust in the pan. If there is then I'm changing the torque converter with a sonnax upgrade.
That would be a good question for Richard. Email him.
I send him an e-mail. Lets wait and hear what he's got so say. Thanks grumpy bear. I'll keep you guys updated.
Got an E-mail back from grumpy bear's contact. He says that he machinnes the pump housing if necessary and puts in a transgo tcc kit and a transgo shiftkit. And after install he tunes the transmission with hp tuners. After all of this the transmission works great and stays that way.
So I'm going to tune my transmission to prevent any problems in the future.
Hi guys,
Here's a update of how things are right now.
I tried to find someone in holland who could reprogram my transmission. After a long search I found a guy who works at the gm import dealer. He could help but asked a serious amount of money. So I did the math and bought my own hp tuner hardware. This was only a little bit more expensive than the gm guy asked. But now I can modify my software as often as I want and it's also usefull to read dtc codes and much much more.
Got a tunefile from grumpy bear's contact and used it to modify the stock transmission software.
Now lets hope that the transmission gets to go way past 100000mls.
Thanks guys for all the usefull input.
did you replace the tcc o-ring on the snout of the pump stator when you changed your converter? this o-ring is what locks or seals the clutch fluid off, if its old and cracked or flattened out, it will leak and you loos clutch lock up..
you should data log the trans first thing.  the tech guy at the tuning school can help you out too. but you have to spend 185 buck on the transmission book to get free tech support for 1 year.
Edited by pokismoki
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
