Has anyone tried to add the HUD to your 1500?  Doing some research and found the 2015, but I'm not sure if the dash pad has changed, the HUD is a different PN.  I am going by the 2020 PN.  I cannot verify the part numbers for the 2021 since the fiche like lead you to the accessories catalogue.  I started with - 2015 Silverado with HUD retrofit/upgrade. - 2014 - 2019 Silverado & Sierra - GM-Trucks.com (gm-trucks.com)
I am Looking at the following PNs:
Mount Bracket: 23407367                                           $65
Driver Information Display Switch: 84456360          $31
Instrument Cluster: 84804721                                    $412
Instrument Panel: 84553050                                       $280   Has dash panel, HUD trim bezel, and mounting strip
Cluster Visor: 84054788                                               $70 Designed for HUD
Head-up Display: 84395830                                         $510
Reinforced Beam Deflector: 23387335                      $10
Outlet Duct: 23391609                                                  $24  - I think this allows you to keep the Drivers side left defroster
Windshield: 84398043                                                 $394
Maybe:
Reinforced Beam: 23387334                                       $339 -  Possible has bracket tabs for HUD - Alleviating the need to remove Driver side defrost vent.  - Might be able to add own brackets.
WAM VIN Programmed                                                $200 + &80 round shipping
Phil’s custom harness                                                  $150 -2014 - 2018 Silverado / Sierra - HUD Retrofit Harness - Harness Dr. - DIY Done Right
* Phil is designing  a 2021 HUD Harness
I have probably missed some things - Like where to mount HUD controls and what bracket is needed.
These above PNs are gleaned off of a 2020 GMC Denali 1500, not a 2021.  Can anyone verify that the PNs remain the same for 2021?
Thanks I appreciate the help and meeting you all.
Wayne
Updated:  18 April 2021
Edited by Thompyt88
Added information
FYI.  If you were polarized sunglasses, you won't be able to see the HUD.  My ZL1 has a HUD and I barely use it, never use it on the street because I wear polarized glasses and never use it at night..  I've used it at the road course a couple of times but never really paid attention to it.
Calling the dealer or going by and giving them the parts numbers and ask them if they are the same as a 2021 would be the best thing to do.
Edited by Vigilante375
Good points on dealer.  Giving my VIN wouldn't help.  Giving PNs to parts guy would.  I am used to HUD.  Had it on a C6 and a C7.
Thanks all
Depends on how clear you want the HUD to be.  I had no issues with my C6 and non-HUD windshield.  But I did eventually replace it.  I was of the understanding that a tint would achieve the same results.    I hear you though.
I used the following PNs:
Outlet Duct: 23391609                                                $24  - Allows you to keep the Drivers side left defroster
Windshield: 84398043                                                $394   (Not used at this time)
All worked well.  Phil's harness works like a charm. There is only 1 screw point to the frame for the HUD bracket.   I used some Ebay parts so the prices was lower.  Best bet is to get dash from GM since parts yards want 150 to ship.  It has a bit less in the display options as compared to a C7 Corvette.
I have successfully  installed the WAMS cluster, harness, and upgraded the steering wheel to get audio controls functional.  I have ordered the Head-Up Display from Nordstromauto and HUD harness from HarnessDr.
Wanting to confirm something before I pull the trigger on ordering remaining list.  Following a couple of the parts list, they all reference the w/o HUD cluster visor.   I 'm grateful for the shared info and advise.
Is the cluster visor the correct part number for the HUD?
Soft touch, without head-up display, black. With leather, without head-up display black.
Should I get?:
Soft touch, with head-up display, black. With leather, with head-up display black.
Thank you,
Chad
Polarized glasses will dim the HUD to your eyes but it's still visible.
  • 7 months later...
  • 2 years later...
  • 8 months later...
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 445 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
