2 hours ago, f8l vnm said:
My 19 was fixed a few months back and so far so good.
One of our 2020 Sierras in our farm has the blue light as well. No big deal for a work truck but we will have it looked at at oil change time. I wish i knew what was causing this , small issue i guess
Do you have a copy of the service ticket on your ‘19? I’d like to know what they did to fix. GM already replaced the entire headlight unit on mine and it turned purple a week later. I haven’t been able to find anyone on any forum that has actually stated anything replaced that actually fixed the problem.
Had mine done last year, replaced the unit and all good so far.
Hmmm... so sounds like the headlight unit they replaced mine with was also defective. Maybe they finally fixed the issue in production. Guess I’ll get mine swapped again.
Went to my dealer earlier in the week for this. Driver side blue on drl only, headlights on- it returns to normal.
First of all, the service advisor douche wouldn't even acknowledge that he saw a difference in the light color.
After several demonstrations of changing from headlights on to auto... he said he'd have the tech look at it. STILL wouldn't acknowledge the color change.
Go to pick up truck today... he tries convincing me that it's the angle that I'm looking at it as it's "a downward angle".  He also says it's on both lights. It's only the angle ! LMFAO.
On the way out I got the service advisors name from a sales guy walking by. I asked him..  he do you see any difference in my drls ? He said, hmm... the drivers side looks a little different on the top. I thanked him and left.
Time to find a new dealer after a call to the service manager to express my extreme displeasure.
Well I was driving home the other day and saw my trucks reflection and noticed that my passenger side DRL finally has failed and turned purple also. So now both my lights match at least 😂
I work in lighting (not automotive) but I can tell you that the reason for the color shift in the LED's is the degradation of the phosphorus over the LED chip. An LED emits royal blue light and they use phosphorus to shift the color to white. When it begins to degrade it shifts the color to a blueish/purple.
Then why is it that is is only when lights are in "auto" mode?
When you switch to parking only or headlight on, the drl turns back to the proper white color.
I have a tech that believes the problem lies some where in between the sensor that picks up the sunlight on the dash and the top drl.
Edited by kj3475
Spelling
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 473 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
