I need to wire my topper cargo light and brake light. It got me thinking how little I use the factory under bed lights.  I would use them more if there was a switch mounted in the bed. Does anyone know of a kit to do that? Or could I tap power off and tie it in with a switch inbetween?
I installed a diode that lets the bed lights turn on when you unlock the doors at night.
Gen5DIY makes a kit:
https://www.gen5diy.com/collections/14-18-silverado-diy-kits/products/external-bed-light-switch-kit
Or if you search the forums there is a thread on here where a guy ordered parts off Amazon for much less and tells you exactly which wires to tap into at the back of the trailer plug.  I followed this way years ago and both switches (factory below the HVAC and 2nd switch in the bed) both work great!
Found it!:
https://www.gm-trucks.com/forums/topic/225685-add-bed-light-switch-to-truck-bed/?tab=comments#comment-2274881
Edited by sk
