How do I get my phones GPS to show up on screen? I can hear it through my speakers, but no navigation on screen.
You need to make sure you have the right radio. If you look at the label in your glove box on RPO codes, do you have I06? What year and model is your truck and what size screen do you have?
Edited by mikeyk101
What kind of phone? If Android, try adding the Android Auto & you need bluetooth on.
2016 Silverado LT. 8" screen, I believe.
Phone is a Samsung Galaxy S10+, so Android.
And the code seems to be IO5.
Yes, either the I05 or I06 will have wired Android Auto and Apple Carplay.
The I06 has factory Nav.
I believe there was a thread here a while ago regarding this.
I have Android Auto installed already. And I can hear the directions through the speakers in the truck when using Google maps, but I don't have anything on the screen of the truck, just the phone. Which sucks. And this is through Bluetooth. I've never plugged in the phone to the truck, and honestly, I don't know where I would, except through the USB port in the center council.
Maybe it simply won't work with the radio I have. Idk.
9 minutes ago, jscottl said:
Has to be plugged in for radio screen to mirror your phone.
Where exactly do I plug it in?
It doesn't mirror your phone.
Apple Carplay and Android Auto only show limited apps such as navigation, messaging and phone calls (others, also, but the idea is to keep your eyes on the road).
If you want to mirror your phone, you're in a different arena I don't recommend.
I plug mine into the USB in the console (bench seat configuration) but, it may work from other USB ports, as well.
I haven't tried that out - I'm good with my set up.
Edited by MikeBMW
Idk. My sister and brother-in-law say their screens show their navigation when they use their phones navigation app. I was just wondering if mine did as well. I'd rather keep my eyes on the road, as opposed to looking at my phone for directions, instead of the large screen in the dash. (Which is the ONLY thing I want. I could care less about the other crap. Only navigation.)
Whatever. I'll just keep doing what I'm doing. Peace.
A couple things, I also have a 2016. Specifically with Silverados and Sierras, the only way to get Android Auto on your radio screen is through plugging your phone into USB in the console like others mentioned. But there also could be another issue if you find that doesn't work. IIRC, Android Auto was first introduced with the  2016 models. However many of the early 2016 needed a software update to allow Android Auto to work. Mine needed the software update. It's not something you can do yourself and has to be done by the dealer. It also takes a while to do. In my case, I think it was almost 3 hours to do. The rub though is that back then, they did it for free because it was advertised as coming with it. I have heard that if it wasn't done then, you will be charged for the software update.
Edited by mikeyk101
Yes, the Nav screen of your phone (maps) will show on the infotainment screen but the phone is not mirrored in the sense that whatever is on your phone will show up on the infotainment screen - and, the selections of your phone apps need to be made from the selections on the infotainment screen.
I will reiterate: Android Auto and Apply Carplay are not true mirroring avenues for phone content except for select apps that will allow you to keep your eyes on the road, put your phone away, and use the infotainment screen in your truck.
You must connect you phone to the truck using an USB cable. You can use your charging cable if you have one. You can connect it to any USB port. Inside the glove box or inside the middle seat storage area. I don't know about size of the screen, but I have an 8" screen. Your phone will connect through Bluetooth for audio, but not video. Future trucks will have wireless NAV support. Some GM cars already connect through wireless. It also depends on the BT version your truck and phone have. Most likely is your truck... GM treats us truck owners like the armpit of customers.
  • Thanks 1
Lovecars, thanks. Yep, I get the audio, just no video. Sucks. You'd think for as much as they gouge us for these things, they'd be better. Oh, well.
Guess I'll trade it for a F-150. They have what I want. Better truck anyway.
Make sure you have Android Auto installed. Then go to Settings on the phone and in the search enter Android Auto and it will give you all the options. The sound comes on because all sound from the phone plays through Bluetooth. So because the sound plays doesn't mean you have it Android Auto installed and configured correctly. I it still doesn't work? the reinstall the Android App from the play store.
Normally the first time you run it, it configures itself to your truck.
I have a 2017 and I have a Samsung S10+ and works perfectly.
I also connect it to my sons Suburban and it works also and it installed itself on his truck also.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
