I'm a newb and appreciate your patience. My High Country has the Grand Lace wood trim on the doors and center console. I'm looking to replace the gray plastic on the dash with the same wood trim. Anyone know where I can get material to do that?
Thanks in advance.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
