Dropped my truck off at a shop for an engine enhancement/tune. Got a super surprise message back I need validation on from the page. See below. Rear drivers side hub/bearing is gone, saying whole assembly should be replaced.
Sound right? Thx in advance.
“We’ve noticed the drivers sides rear axle was leaking fluid when we moved the truck yesterday.  We pulled off the wheel/axle thinking it was just a bad seal.  However, inside axle tube, the wheel bearing is completely torn apart.  There is no bearings left in the bearing case.  So essentially the axle was riding around inside the tube with no bearings.  No one here has ever seen that happen before.  The inside of the differential tube is destroyed. Basically the entire rear axle housing needs replacement because of that. “
Well, technically it's not "destroyed".
You could clean all that up and make it smooth there again, then pound in a new axle bearing because the rear axle rides on the bearings that are held in that bearing case.
The tube is no longer round. Oblong.
Where did the bearings go?
the wheel did take an impact 2 years ago when someone ran a stop sign and hit my wheel. I never felt any shimmy or shake at all - that is what drives me crazy. Maybe 10k miles since hit that tho. Baffling!
Pull the diff cover, see what you find in the bottom. Might be chunks of metal in there.
If it's oblonged, then yeah I guess you need a new rear axle.
The image doesn't really show "Out of Roundness", might be worth a try to have them clean it up and try a new bearing and seal, just monitor it, now if they do not want to try it, then short of having the truck towed back home for "DIY" then your stuck!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
