Trying to find out if there’s any good brand of retractable bed cover that has the pocket holes for the bed grap hole exposed.
 New AT4!!
I have not found a retractable bed cover that doesn't partially cover the stake holes.  Retrax and Advantage (same product, different label) both partially cover the stake holes.  Roll and Lock looked like it also does based on photos I found online.  Becoming aware of this, I decided to fill the stake pockets with caps and mounted the pole handle the multipro tailgates come with.  It is a perfect fit with the Retrax bed cover.
11 hours ago, blckblt said:
Here is a pic of my MX4
I don't believe any of the tonneau covers you've recommended would be considered "retractable".  They are either trifold or quadfold.  Retractable bed covers are like garage doors that roll into a canister.  They are $1000+.  Powered versions can be over $2000.  If you look into the ones I mentioned above and you'll see the differences.
