No, a RST doesn't sit 3" higher than an LT.  They should be the same ride height.
You haven't really told us anything about your truck to help identify the exact package needed, so hopefully this helps.
https://accessories.chevrolet.com/product/lift-suspension-upgrade-system-for-4wd-vehicles-84993582?model=Silverado 1500&modelId=491&bodyId=22&body=Crew Cab Pickup&wheelId=652&wheel=Standard Box&trimId=478&trim=LTZ&driveId=8&drive=4WD&engineId=5920&engine=6.2L V8 GAS&bodyNumDoors=5&year=2020&make=Chevrolet&categoryId=98004
Edited by Transient
i have stock 2WD with Gov lock ,2016 LT truck, looking to do some gold prospecting and exploring here in California and AZ , so I travel lots of dirt roads, I'm scraping a lot in the ruts and need a 2-3" lift, but dont want to change my stock wheel tire combo
i noticed several new 2020 rst trucks sit much higher than mine and wonder if GM has done a lift on these vs My LT truck?
i do like the front camera option, as i can never see where i'm going when i round the top of a hill for decent..
Edited by pokismoki
Hello from South Carolina!
I just purchased a Z71 RST, and was looking for what part numbers from the GM Factory 2" Kit I would need.  I have heard many things in forums indicating different things, but the dealership noted that I would require the entire kit for my truck.  While I would be a little skeptical, the service department manager has the same truck as I do, and showed where he had to do the same.  $1600 for the kit and complete install.
Where do we start with this one?
The new T1xx trucks (2019+) are completely different from previous generations, starting with the frame and going up.  You're comparing apples to oranges.  If the new RST sits higher than your 2016, then start there.  If you need 2 more inches on top of those 3, get the Trail Boss suspension package I linked above.  Or, just buy a Trail Boss from the start.
Your other option is to go with an aftermarket lift kit for your 2016.
Edited by Transient
See posts 2 and 6.  Same part number.  GM is only selling it as a kit.
ok, not sure I would want to waste good money overpaying for a new RST or z71,  I figured the T1 chassis are still fairly similar to a k2xx being so close generation wise..  but i see THere are other ways to go about it. not using GM parts.  I just figured they put in a little more engineering the kit than aftermarket but i'm usually wrong.
also wondering what would the opinion be on a spacer lift vs a Knuckle lift?
Let me put it this way.  My neighbor bought a 2016 F150 new 5 years ago for $39k.  He just sold it to a dealership earlier this week for $36k.  It was his daily driver.  Losing $3k over 5 years is a he'll of a good deal.
Now for his bad news.  He needs to buy a new vehicle.  Due to the microchip shortage worldwide, I wish him luck with that.
5 hours ago, pokismoki said:
i would never own a T1 they are ugly , and just to tune one is a fortune.
You're entitled to your opinion, and I'm entitled to disagree.  But, keep in mind professional athletes are not chosen for their looks.  They are chosen for their capabilities.  You wanted a truck that could a desired result.  If you think a T1xx serves the function, then get one.  If you're looking for a supermodel, then this truck isn't the right one for you.
Then why come to the T1 forum to impress us with your ignorance?
T1 is a ground up whole new frame compared to K2.  K2 was a minorly tweaked GMT-900 frame.  Nothing is the same between the two frames.
What more "engineering" were you expecting?  The GM 2 inch kit is literally all the parts pulled from the Trail Boss.  The longer shocks, extended CVs, crash compliance brackets, blocks, longer u bolts, etc.  The parts were already "engineered" for the Trail Boss.
Edited by newdude
I would never own a 2016 LT 2wd, they are fugly, and tuning can't fix fugly.
  • Haha 1
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
