No, you didn't get a lemon.
Yes, there has been a rash of AFM/DFM lifter failures in the past year.  Dealer will fix it and it will be all good again.  Typically its a lifter or lifters, plus any bent pushrods.  If you have a cylinder fail on each bank, dealer will replace all 16 lifters.  If one bank had the failure, that entire one bank will get 8 lifters.
Edited by newdude
Happened to me around 5,000 miles.  2021 Suburban z71 5.3.
First time left bank, 3 weeks later right bank..
Almomst 3 weeks in the shop.
Seems to be good now!
17 hours ago, Rich Hanley said:
Pretty severe bend in the push rod. Is there a way to disable the DFM system and/or is GM issuing a recall?
No recall.  Not sure what GM has layed out for any plans other than fixing the ones that break.
None of the AFM/DFM disable devices work on Tahoe/Suburban/Yukon/Escalade.  These SUV's are on GMs all new Vehicle Intelligence Platform or VIP which replaces Global A architecture for vehicle electronics and module communications.  The ECMs have not been "cracked" if you will, nor has anyone validated fitment of devices like the Pulsar LT to work.
There is another thread on this.  It speaks to the errors that are shown when this happens.  My truck has been at the dealership for over a month now.  Still waiting on parts.  There is nothing I or they can do but wait on GM to deliver.  The sad thing is that they knew exactly what was wrong when I dropped it off.
Been in for 21 days now.  Just hear from dealer. Parts will be in tomorrow.  Replacing all 16 and guides.  Looking forward to having my brand new truck back!
I just got the call from the dealership.  My truck is ready.  I stopped by there the other day and spoke to the technician.  He had them order parts for all cylinders so the top of the engine was completely tore down while I was there.
GM suggested that I test drive the truck with the technician so I could point out anything that I thought was not normal.
I also spoke to GM about lemon law and options.  They said they were working on rebuilding trust in GM vehicles and were willing to discuss reimbursement option if I decided not to follow the lemon law route.
If all is well and accepted, it will have been at the dealership for 38 days.
Make sure they put a new serpentine belt on after the repair. The dealership did not do that for my vehicle and that left us stranded on the highway for 5 hours in 100 degree weather waiting for a tow truck. Not to mention the $800 for towing, lodging and repair at another Chevrolet dealership. Could have easily been avoided…
They did not put a new belt on.  What would warrant a new belt?  I am not at all saying you are wrong.  Just curious why?
GM is offering me compensation.
Just not sure if I should try to lemon law my truck, even though I guess it is fixed now.
Or, maybe try to exercise a buy back or something like that.  Only problem is, trucks a pretty slim pickens right now.
What is GM offering you?
If they
just wondering if folks have heard of offers from gm "to rebuild trust".  my z71 is in the shop for 14 days now. broke down with lifter problem and cyljnder misfire at 10000 miles and while we were on a 2 week road trip.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
