Hi all i have a 2007 1500 thgat wont crank. The other night i drove it fine then tge next morning it wouldnt crank. Other symptoms are no radio, window wont work, dash takes a few seconds to turn on, service 4 wheel drive, service airbag, dome light doesnt come on wgen i open thge driver door but comes on when i open the back door, and there might be more but i cant think of any at the moment. The door locks and blower fan both still work. When i turn the key nothing happens. Any ideas what the problem may be?
Battery?
You don't say how old it is.
Check the condition of battery cables and their connection battery and ground. For sure have the battery load tested
Sounds like a tough issue.  The battery is only 7 mos old, and Napa doesn't usually deal in cheap stuff.  Still, a battery can be defective by any brand.  I would start with having battery fully tested --- load, short inside the battery.  Other than that it will probably take a good mechanic to find that issue.
Any wiring that you can see thats been chewed on by mice?
Is power getting to the spark plugs?  If not, you might be able to trace it back from there.
If it didn't try to start when you tried to jump it then there is an issue with the wiring somewhere.  Like stated above.  Make sure the cables are good.  Sometimes corrosion can be inside the cable casing and you can't see it but it stops the flow of electricity.
I forgot to mention that the line under my park reverse neutral and drive isnt there anymore to indicate which gear i am in. Also i had my rear main seal replaced 2 weeks ago. Can something have gotten pinched under there while they were working on that??
quite possibly a ground didnt get tightened or got damaged in the process
You need to start a process of elimination. Check all wiring. Make sure no damage from work performed. Check starter.
Battery cables etc.
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,530 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
