Hey guys. Idk if it’s me but I cannot seem to find replacement rotors and pads for my 2019 RST.  I have the larger brakes (Brembo I believe?)   I ordered front and rear rotors and pads and they were all for the smaller brake setup, which I now need to sell.
can anyone point me in the right direction?
Here? https://www.brembo.com/en/company/news/brembo-brakes-gm-suv
5 hours ago, Transient said:
Have you tried going through a Chevy dealership parts department?
 I was not looking to replace with OEM. I’d like some slotted rotors and better pads if possible.
What I'm saying is, if the Brembo brakes are offered through GM then they'll have a part number and you could buy from them that way.
As for "better" pads, I've always been a fan of Wagner Thermoquiet pads.  These can be found at O'Reilly's, and other popular auto parts stores.  For some vehicles they make severe duty Thermoquiets.  The difference is whether or not you do a lot of towing.  Thermoquiet pads are ceramic.  I then usually find some decent slotted and drilled rotors on ebay.  I did look for slotted and drilled rotors on ebay, and I found them.  I also looked at RockAuto.com and found them under the rotor and pad package subgroup.  I went 2 for 2.  If I found some that easily then you should be able to also.
The kits you saw on Rockauto all say for Silverado LD which is not the bigger 6 piston brake kit or they say Base which is the smaller base model brakes which I unfortunately have an entire front and rear setup for.
Thank you for completely ignoring my first paragraph in the reply you quoted.
Lol. My bad.  I found the correct part numbers and was able to source then
on eBay thank god.
on eBay thank god.
Glad to see you found them
fyi - For the money, I'd rather spend that amount for all 4 wheels. Wilwood and Aero are a couple options vs. Brembo.
    KJEK
    KJEK
  • Who's Online   3 Members, 0 Anonymous, 461 Guests (See full list)
