Hey, I recently received my 2021 Silverado 2500HD. I ordered with the WT trim. I have it optioned up with Alaskan snowplow prep, and the WT safety/convenience packages. It has integrated trailer brake controller, aux battery, and that’s about it.
It has been a great truck so far.
I was hoping I could get some insight as to what everyone else’s door tag tow sticker looks like. I have no idea how to upload photos but mine is:
Con. TWR= 12000lb
tongue= 1200lb
goose TWR= 16620lb
Tongue= 2490lb
Curb weight 7063lb
payload 3587lb
Now being that my travel trailer is 7000lb dry I really have zero concern about any of the numbers, however I have always thought the conventional trailer tow rating on these gassers was supposed to be more in the 14,500 mark.
any ideas why mine is so low? If I recall correctly I think the truck being equipped with the 275 70 18 Hankook Dynapro MT2 may have changed the rating when I built the truck but any other insight is great. Thanks!
This doesn’t help a ton but something is definitely off…my Duramax Denali has a max payload of only 3065 but an 18500 conventional trailer rating.  I doubt the tires have anything to do with it, they may effect your max payload but not your towing capacity.  Maybe someone with a gasser can chime in but those are my numbers.
It is due to the tires.  These hankooks are great off road but, you deal with some sway on the larger weight conventional trailers.  You will have no issues with 7k trailer.
#iworkforGM
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
