5 minutes ago, bigbulls said:
Sorry it took so long my contact was on vacation. Your engine was built in Spring Hill Tennessee.
Thanks Firehawk99 I just crawled under and took a picture of my Julian tag and it starts with N and I was going to ask the same question. May 12th 2021 for me and Vin build date is 6/21 so it looks like it's running about 3 weeks to a month difference from engine build to truck build. Thanks again for all your info.
Anytime! Happy to help out.
Thank you, Firehawk99!
Back in the shop, after all lifters and a bent pushrod were replaced I picked it up and started shaking badly at about 40 mph and on light acceleration or when coasting. Was able to get it home, called my local dealer who said no appointments until 9/20 or drop it off and they will get to it when they do. Continued driving it as it wasn't horrible and no check engine light until I started smelling burning oil. Look under the hood and see oil pooling on the the intake manifold dripping down onto the exhaust manifold. Didn't have a choice but to drop it off at the point. Now waiting 5 days as it's a holiday weekend to be looked at without a loaner.  Take as long as you want to repair it, once it reaches a total of 30 days I will get and attorney and proceed with lemon law. GM is useless and their " senior rep" never picks up her phone. Horrible customer service.
On 8/5/2021 at 3:31 PM, Firehawk99 said:
Any trucks built after 3-4-21 should be fine. That is the break point.
My question is, what changed? Hardware or software?
I bought my trail boss in March , just over 7000 miles , was told they are going to replace all lifters. They won't send me a copy of the bulletin. Anyone know the exact cause for the lifter failure , they said the springs but I read somewhere it was from bent push rod.
I have a 2021 Denali w/6.2 that has a truck built date of 02/21.... have 13k miles on it... I haven't noticed any issues yet, should I get the Pulsar sooner rather than later?  thanks!!
On 8/5/2021 at 1:26 PM, Firehawk99 said:
I work for GM at the Tonawanda engine plant. We build the 4.3, 5.3, 6.2 and the 6.6.
can you confirm is this the lifter sound of a possible issue?  This is on a 2021 Tahoe with the 5.3
https://youtu.be/4XMoY7Y1e1k
2 hours ago, Firehawk99 said:
It sure sounds like it to me. I would park it and have the dealer come pick it up.
Cool, thanks 🙏🏽 luckily it’s on a vid I pulled from another forum. I asked here because at first to me it sounded like injectors similar to this video at 5:20+
9 hours ago, Firehawk99 said:
Your engine was built in Canada at the St. Catharines powertrain plant.
Awesome! Thanks for checking on it. Do you know if it’s possible to get an engine build sheet?
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 834 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
