I have tried searching and only seem to find things for the older style trucks 2018 and before. Does anyone have a link or write up on how to change the fluids on the axles?
I'm sure the rear is pull of the cover to drian? I think I read on here the front axle is now the same no drain plug like the older trucks?
I'm doing an oil change this weekend I'll do some crawling around and see what I can find. I have 15k miles thinking about doing both front and rear axles at 20k.
Also if I understand right there's two different fluids depending on who makes your axle? Looks like I got aam axles so that's 19300457 high Efficiency 75w 85 fluid for both axles. I have no idea how much. Owners manual says see my dealer....
Thanks for any help.
Edited by Adamace1
Looks like I found the correct fluid for the axles at the dealer. I'm going to hold off on doing the axles untill 20k. I need to find out if I need to buy new gaskets or if they are reusable. And what is the proper fluid level, sometimes it calls for fluid to be below the drain plug. So I need to do more research.
I did do transfercase oil.
Plugs were easy to take out. I took out fill plug first. Then the drain plug. It took about 1.5 or more quarts of DEXRON-VI. The fluid was just a tiny bit darker than new fluid but was red. I only got 15,000 on my truck so that's what I expected. It was barely running out when I took the fill plug out. I filled it up to the same level then put plug back in.
So if anyone knows I have few questions.
1. How much fluid is in the front and rear axles?
2. How high should the fluid level be compared to the fill plugs?
3. Are the housing gaskets reusable or do I need to buy new ones?
Edited by Adamace1
If I read the owner's manual correctly, you only need an oil change and to rotate and balance the tires at 15,000 miles.  Why would you be servicing axles, etc?
Why not? Doesn't hurt anything. Easy, cheap.
I guess it’s one of those it doesn’t hurt to do so deals. It got me thinking. My latest truck had detailed maintenance records. The guy changed the oil every 3K, filter at 6K. Very old school. Still cold mornings under 40 degrees the lifters are noisy. He never changed the differential. I did at 168K, when I got it. Another interesting point. Iv been using dealer service for awhile. GM,Ford Ram, Hyundai, Toyota in that time period. Their favorite service is injection cleaning. The manual says if you use top tier gas your good. Non of them say a word about deferential, power steering or antifreeze. Interesting.
My 2021 owners manual never says to change the front and rear axle fluid. Doesn't tell you what fluid to use. Half the reason I want to do it is to make sure it's the correct fluid, and that it's filled properly.
I do my own maintenance. I'm sure 99 percent of the time the kids doing the oil change never check your axle fluid. For anyone who has has a rear axle lock up on them because of low/ bad fluid you will understand how important it is to maintain them.
Edited by Adamace1
Humm injection cleaning, pour a 2 dollar little container into the gas tank for 159.99. My manual does give a recomend antifreeze flush timeline.
They push the services that sell IMO. How many people do transmission, coolant, differential etc. Me and 2 other people I know do these services. Most change the oil and fix it when it breaks. One of these people is my son, who is a mechanic.
The last time I looked it was 150K. It my be going the permanent line now. My 04 GMC had it at that. I changed it and right after my water pump seal started leaking.
In my pulling days. It did running gear half the recommended with Amsoil. Especially the transmission. Amusing from what I read about some people feelings on oil changing. The engines I didn’t. Also on Amsoil. As long as the engine didn’t over heat. I stopped pulling my equipment in the early 2000s. I amused and amazed at oil change threads on here. You look it up on the net. The average life of a vehicle is nearing 200K. Most vehicle manufacturers are extending oil change intervals. GM may be lowering theirs. May have something to do with cylinder deactivation. Let’s keep that our secret. Even though they  increased oil capacity. One dude on here added engines are junk to his oil is junk threads. Still vehicles are lasting longer. Puzzling.
The dealer did have a scrolling tv with prices on it by the service area.
Tranfer case flush was 127 I paid 25 and did it in 5 minutes.
Their per axle price for diff fluid change was 179 per axle. So 358 plus tax. I belive it might cost me 90 for the right amount of fluid, not sure if I need to buy new gaskets for the diff covers. But I should be able to do it for 150. So in 3 hours of work I'll make $113 an hour working on my truck. I will also know it's done right. Lol once I figure out the axle fluid level, and if I can reuse my gaskets.
1. Still wondering are the rent and rear axle cover gaskets removable?
2. Where should the fluid level be on front and rear axle? I checked rear and fluid was almost 1/2 inch down from bottom of fill plug hole.
Edited by Adamace1
The dealers got a new tool for changing axle, it sucks out the fluid.  A friends kid got a job as "Lube Tech" at the GM dealer,  Said he can do 2 per hour, asked what lube they put i?  Says don't know, comes out of a hose connected to a tank in the oil room.   Easy money.
Edited by elcamino
Quote
That may the spec, some say not to overfill and leave it below the fill hole.
When they fill the axles in the axle plant, no one is measuring it out. A tool is programmed to fill with a certain amount and it shuts off.  If they let the operator make that decision he might fill it to the max and cost the company money.
Edited by elcamino
Yea thats what I can't find out. Where the fluid Leven should be on my front and rear axle. Tried searching on here, on Google, on YouTube. Its a mystery
Find the amount of fluid they take and put that amount in.
    • And to top it off finally.......................these small GM LS engines are designed to SPIN!!!!!  Why choke them down to just off idle for cruising.  Why/how the "bean counters" have influenced the "engineering department" at GM is beyond me.   They took a solid platform of an engine and turned into a joke in OEM form!!!
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
