I want to go to a light truck tire on my 2018 Sierra Denali. I like the wheels on the 2021 GMC AT4. The ford dealer could not tell me if they would fit my truck. They said the only way is to order them and try them. That does not sound right. Dow's anyone know if the 2021 Sierra 1500 wheels are interchangeable with the 2018's?  Thank for any comments.
I would, "assume" so. Just by looking at them they probably have similar, if not exactly the same offset's. I could use google and compare specs between the two wheels. But so can you!
Edited by M1ck3y
Any of the 2021 and prior wheels will fit a 2014-2018.  So anything 2007-2021 will fit.  The new body 2019-2021 guys can't run older stock wheels without a wheel spacer.
You will need new or transfer your tire sensors as the frequency used in a 2021 wheel is different.  They are 433mHz, your 2018 most likely is on 315mHz.
Edited by newdude
    d.lowrey
    d.lowrey
  • Who's Online   6 Members, 1 Anonymous, 2,702 Guests (See full list)
