If like the GM Performance CAI on my Camaro, it only recalibrates the MAF sensor to correct the airflow reading and thus the air/fuel mixture.  So yes, it would correcting a rich or lean condition - could be either I think as even though the main purpose of installing the CAI is to increase airflow, the airflow pattern and location of the MAF sensor affect it’s readings.
Edited by RCF71
9 hours ago, Toolman4 said:
Does anyone know how this reprogram affects performance.  Is it running rich since it says it might exceed emissions standards?
The dealer told me that it does not change the tune but it reprograms the MAF for more air.  I am not sold that it is the best system on the market, mine was part of the deal.  If I was doing it again, I would look at better flowing systems like AFE. Do you have the bulletin number, I have not seen a recall on them yet.
As I understand this recall, it only affects those who ordered the performance intake that was installed by the dealer, who then failed to perform the ECM update that is an integral part of the intake installation.  Those, probably the vast majority of people like myself, who had the ECM update performed as part of the intake installation, are not affected by this update.  There's at least one other thread on this site that has addressed this recall recently.  It appears that some people are interpreting this recall as involving all performance intakes, which is not the case, but just those where the dealer failed to follow the installation instructions and install the update when they put it on the vehicle.
I dumped the paper for the recall #, but mine was a 19 at4 and this was the first I heard of it.  It seems to me it would be running lean without the adjustment, but they make it sound like it's a epa rich condition. I get 19, 20 running down the road with the 6.2 and factory lift so I don't want to affect the mileage or power.
Lean conditions can also cause excess emissions, just different emission components.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
