Has anyone installed the Rough Country 3.5” Lift on the 2021 Silverado High Country with ARC? If so what are your thoughts?
Edited by Smitdog
Thinking about the same kit for my 21 Denali.  Let me know what you think about Joe after the install!
It turned out great! Ride is identical to factory Denali . Lift is perfect height to look aggressive but not over compensating 🤣
Looks great
Looks impressive!!
Smitdog I can't answer ur question directly but I owe a 2013, I bought used that had some sort of leveling kit on it. I caught the itch to go high so I did. Bought the 7" Superlift suspension lift kit and installed it in my driveway. I'm no mechanic! But as a construction trades welder I had the tools to be confident I could install it and I did. RC price wise is the cheapest brand. That alone scares me just a bit. Ask as many knowledgeable people as you can. Body kits are very easy too. I shop at Amer. Trucks.
Good Luck!
Got my 3.5” kit installed this week.  As others have said, ride is just like factory and gives me the stance i was wanting
I installed the 2in leveling kit from Rough country swapped the factory option AT tires for some BFG KO2s. I am happy with height, didnt have to cut anything, no wheel spacers.
  • 2 years later...
Does this lift still have the truck a little higher in the rear? I got the lift and ordered 2in and 1.5in blocks to use in case the included 2.5 rear blocks were too tall. Thanks.
The back is a little higher right?
On 8/21/2021 at 9:02 PM, mdf21 said:
Looks great
Did you have to cut any stock suspension parts to fit the 3.5” RC lift?
