My 2021 Chevy trail boss Bluetooth is undiscoverable, it worked fine one day then the next day it wouldn’t connect. I unpaired for hit forget device. Now the truck don’t even show up on mobile devices. I have connected via USB cord and the information systems just keeps saying retry. I have tried connect multiple different devices to no avail. When I go into phones and try and touch add phone it is grayed out. What can I do to fix this.
I semi have the same issue. Sometimes CarPlay will connect, other times not. When it doesn’t most of the time Bluetooth will not either. I haven’t had any luck with the dealer, but there are a couple of service bulletins for software upgrades related to Bluetooth and CarPlay. Maybe that might help.
I have consulted the owners manual and tech support who did multiple force restarts on my truck. They are suggesting take it to the dealership which where I live and my job it tough as they close at 5 pm and are not open on the weekends. I was just looking for other possibilities for a fix or what the issue is.
Unfortunately, it sounds like you'll need to take it to the dealer.  I have yet to find a dealer that doesn't do after hours drop off.  I use this service often.  The real question is, how big of a back log do they have?  My wife's Traverse had a leaky trans line.  Dealership said they were backed up 3 weeks on trans repairs.  And, because they were first come first serve they wouldn't hold a spot in line if she put her name on a list.  They wanted the car to sit there for the entire 3 weeks.  I took it to an Aamco and was out the door a few days later and only $200 poorer.  The leak turned out to be a damaged o-ring.  Hopefully your dealer isn't like mine with the long waits.
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
