Went in to order a 2022 Silverado 3500 CC, and of course can't get a confirmation due to the chip shortage. Anyways, wanted to hear from you guys on the good/bad so far on the 3500 Silverado platform with the 6.6 Gas motor, 3.73 axle, 159" WB
There are several recent threads that cover this subject.
I’ll sum up:
Bottom line is a bunch of us have bought the gas truck and are very happy with it. Meanwhile, the diesel guys tell us we should have bought the diesel.
Edited by Another JR
Correct typos
  • Like 6
  • Haha 1
I traded a duramax L5P in on my new 6.6 gas crew LWB.  I’ve put a couple thousand miles on it in a short time and am very happy so far.
I don’t tow heavy (4-5k) and have put 5-6 hrs drive time towing also and was surprised that it actually tows better than my 17 6.0 with 4.10s.  I assumed the 3.73 would cause more shifting on inclines that it actually does, especially with the 37s I’m running.
Whatever changes in programming that have been made to the 6sp tranny, coupled with the 6.6, make for a nice driving experience.  This truck is noticeably different/better than a 6.0
Couldn’t tell you exactly what kind of mpg I’m getting-never cared enough to check but I’d bet it’s 12-13 unloaded mostly highway.  My duramax regularly got 14-15 per tank hand calculated on the same lift and tires.
Sorry Polaris1man if my attempt at humor delayed people responding to you.
Regarding gas mileage, I get a little over 17 unloaded on the highway at 65 over low altitude rolling terrain. Running 70 plus drops it down to 16. I get about 15 with my pop-up slide-in truck camper that weighs about 1700 lbs and sticks up sbout 12 inches above the cab. I can’t offer any towing numbers yet.
Like I said, I’m very happy with the gas engine and 6 spd transmission for my use, including some towing of an 8000 lb boat trailer.
My only complaint about the truck is not engine specific:  the visibility to the front for off roading sucks because of the stupid “I drive a semi” high front end styling, and the giant mirrors seriously block the view of cross traffic and pedestrians at intersections. Even after four months if driving it I still occasionally slam on the brakes turning a corner because i see a car speeding at me from the right in my peripheral vision when really it’s a car passing behind me appearing in the huge mirror that blocks the front third of the passenger window.  I’m surprised the DOT allowed those  mirrors.  I’m hoping for an aftermarket mirror change, but not holding my breath.
The "drive a semi" high front end didn't bother me as much as for my wife, gonna need a couple of boat cushions for her!! I'm not too concerned about the mileage factor on the truck, just asking what to expect, guessing a 36 gallon tank will be enough to get one one Gas station to another.
Here is another question; any of you 6.6 Gaser's running aftermarket exhaust? GM recommends the Borla single, also been looking at the Flowmaster American Thunder duals, any thoughts?
Well, been watching the build of my '22 Silverado 3500, and now see it has left Flint MI via train and expect delivery around October 10th. Didn't go for the Denalli, hope to be happy with the LT model as I needed cloth seats for our 3 kids (Dogs) to avoid Leather scratching. Added 20" rims, tow mirrors, electric rear window, what ever tailgate with drop, running boards, bug shield, and a few other items. So does anyone have any news on the Cold Air Intakes and exhaust accessories?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
