The TPMS warning light on my 2015 Silverado lit up and the panel indicates the left front tire is low. It shows a pressure of 28-29 pounds. Actual pressure is about 32-33. Did not change any tires and did not add air to any tire recently. I know nothing about these contraptions. Suggestions on where to start are appreciated. Thank you.
Time to either get your TPMS re calibrated or replace the TPMS monitor at that wheel.
Edited by MikeBMW
Put air in your tire and the light will go off. Your manual gauge could be wrong.
I have like 8 different tire pressure gauges, none of the slide style read exactly the same. Bridgestone used to send us boxes of like 200 at a time when I worked for that shop. I'd break them or they'd blow apart all the time. More often than not they are sorta accurate but that's good enough.
Edited by CamGTP
When you check pressure in other tires, do they match on your hand held gauge?
Aired all 4 tires up to 35 and disconnected battery. Warning TPMS light is now out, but only one tire shows pressure (31). The other 3 on my display are just "dashes". My screen also insists it is January 1 and 35 degrees. It's been in the 90s here for days!!! I ran it about 8 miles but perhaps it requires more calibration to set everything. Am on my second display as the other one gave up the ghost about 2 years ago. Was out of warranty but luckily GM picked up the tab after alot of complaining. Hope I don't have another issue. Appreciate the comments and help.
I would do the battery disconnect again, but also turn the key on when disconnected.
youill have to rest your clock and drive 5-10 miles and your thermometer will readjust.  You may need to visit a tire shop or the dealer and see if they will rescan your tpms   Def sounds a little off.
Thanks all. Everything working OK now except left front reading 28 psi and the others 31. I'm sure there is 35 in each one. Checked with my motorcycle tires which I keep real close and also a second gauge. Light is off which is the most important. Has anyone used the available on e bay tools which allow you to reset your TPMS?
I bought the Autel TPMS TS508.
I suggest one stay away from the cheap ones, JMO...
Bought this from Amazon for $19, works on my Silverado and Malibu.
VXSCAN TPMS Relearn Tool El50448 Auto Tire Pressure Monitor Sensor Reset OEC-T5 for GM Series Vehicle
    • We want you to have full confidence in your Silverado, @ceeemcgeee. Safety is our utmost priority, and we understand your concern after this experience. We would like to provide an added layer of assistance between you and your dealer as we pursue the resolutions of your transmission concerns. When you have a moment, we would like to learn more about your experience so we may explore the best path of assistance moving forward. Please visit: https://s.chevy.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • Disclosure: BlueV8 is a Supporting Vendor and sells plug-in AFM/DFM disablers.   Before you spend a dime with us — or with anyone — try the AFM disabler GM already built into your truck. It's the shifter, and it's free. ⏱ The 10-second version 🚫 Skip the M5 method if: Most of your miles are highway — M5 locks out 6th gear, so you cruise at higher RPM and burn more fuel You already know you'll forget — it only works if you do it every single drive Your lifters are already ticking — nothing that switches AFM off repairs existing damage You already run a tune or disabler — this would be doing the same job twice ✅ Worth trying if: You want AFM off today, for exactly $0 You want to test-drive V8-only life before buying anything Your driving is mostly town and short trips, where 6th gear barely matters Your truck is leased or under warranty and you won't touch the ECM — this is zero hardware, zero software 💡 The whole trick, in one paragraph Owners across GM forums keep reporting the same pattern: put the transmission in manual / range-select mode, pick M5 or lower, and AFM never activates — the truck stays in V8 the whole drive. Bump it up to M6 and V4 mode comes right back. Two of the cleaner threads on it are here and here. GM has never documented this behavior, so file it under "strong owner consensus," not gospel. The good news: it takes exactly one drive to verify on your own truck. Steps below. What "free" actually costs Effort, every drive. It's a routine, not a setting. Shift to M, tap up to 5, every time you get in. There is no set-and-forget here. 6th gear. When GM shipped trucks with AFM/DFM switched off during the 2021 chip shortage, its own estimate of the penalty was about 1 MPG — and those trucks kept every gear. In M5 you're also giving up overdrive, so expect the highway hit to be bigger than that. Patience. One Tahoe owner ran the L5 routine for two months, then got tired of it and bought a plug-in disabler — he had an extended warranty, so flashing a tune was off the table. That's not a knock on the method. That's just what month two feels like.   I put together the full instructions, limitations, and links to the original owner discussions here: https://www.bluev8.com/blogs/news/how-to-disable-afm-for-free-the-m5-method
    • Disclosure: BlueV8 is a Supporting Vendor and we sell AFM/DFM disablers. We wrote this because not every GM owner actually needs one. In some cases, regular maintenance, towing use, an existing tune, or simply using M5 makes another device unnecessary.   ⏱ The 10-second version 🚫 Skip it if… You keep the oil full and change it every ~5,000 miles. Your risk is already low. You're happy shifting into M5 every drive. That disables AFM for free. Your truck tows heavy most days. AFM barely runs under load. You already run a tune or delete kit. Done is done. It's already ticking or misfiring. You need a mechanic, not a plug-in. ✅ Worth it if… You bought it used and the oil history is a mystery. Checking the dipstick is… not your hobby. (No judgment.) You're a long-term keeper with lots of easy highway miles — exactly when AFM runs most. The V4 drone and shudder drive you nuts. You're under warranty, so a tune is off the table.   The full article includes the supporting GM bulletins and owner reports: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler
    • It`s magnetic so it`s not main or rod bearings. I would pop off a valve cover or 2 and take a good look at the rocker arms. See if you can see if any needle bearings are coming apart.
    • Hey yall.   I have a 2015 GMC Sierra 1500 5.3 2wd. I just did my own oil change (currently 132,000 miles) on the truck for the first time since I got it. It has always had routine maintenance done at the correct time. Never once had a check engine light, oil pressure light, or any light (except low fuel lol). Also never towed anything ever. It has been a daily driver for me.   I noticed the dipstick has metal shavings magnetized to the end of it. And even after wiping it and putting it back in like 12 times, it still pulls some out. The oil filter also has a good amount in it.  It has always ran perfect and still does. Never ever had a weird noise or knocking or ever ran rough. Almost too perfect lol. So this metal has really surprised me. I see some similar stories where people say this is normal wear, others say your engine is cooked. I know it’s hard to say for sure without seeing in person but just wanna see if anyone has had a similar experience at this mileage or any advice?   Thank you in advance.
