I have a 2021 Sierra 1500 AT4 with the 3.0 Duramax.  So I got a notification there was an update for my infotainment system today, it said release date was 9-13-2021 I don't recall the update number.  I did the update.  After the update I started the truck and it is idling very rough to the point that the truck is shaking, the service ABS light is now on, and the traction control is stuck in the off position.
Has anyone else had this happen?
Is the battery low after doing the update?  Not sure how long it takes so curious if you had to leave the truck on, etc?
It only took 11 min for the update and they said the truck must be turned off during the update.  I didn't notice the voltage being low at all after the update. I will check on that in the morning.
OTA updates on these trucks are only for the infotainment computers and not the ECM.
Something else is causing the ABS issues and idling issues.
Mine has been wanting in install the update too.
I it (also a 21 3.0) install today too.
We were out and had several stops to make.  At the first one that was going to be longer than the 10 or 12 minutes it needs I had it do the install.
On return to truck it said it had completed successfully.
Stopped at several more places before returning home.
Truck running smoothly as it always does.
Gotta love GM and their "Reliability" 6K miles... should not have all these issues with it.
 We're having terrible infotainment troubles. Still no update for us here, the dealer is WEEKs out. We cant even use the hotspot, and havent been able to for months.
Onstar says to update our infotainment as its from last year (seems the dealer DOWNGRADED our infotainment when we had the original problem of no internet at purchase). I think it says Build is 105, and v155 is out now?
Wonder if there is any other way to get this update.
I live in an area where it will not download properly and I have to take it to the stealer for a proper install.The problem is until I get to the dealer the radio will not work properly even when I push the download later option. They also cannot turn this download feature off just another example of GM engineers spending HOUR of time to work the bugs out of a system they say can't fail LOL
Iirc, 'Download later' will ask again before it downloads.
You have to 'install now' at one of the times if asks.
That would be great but it never completes the install where I live so it just becomes a viscous circle.  Therefor the only resolve is a hard download at the dealership 100 miles away.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
