L83 5.3L Flex fuel conversion with Dyno sheets. Followed with tune and more dyno sheets.
1 hour ago, CamGTP said:
Who is doing the tuning?
No idea yet. Haven't thought about it. +20whp on the stock tune will do it for a while. I will probably mess around with it for a little while. I need to see what tuners in Chicago are good with Gen V trucks.
Well, who did the tune to enable the flex fuel?
Or do you own the software to make those changes?
I can easily just post a few tunes I've made here.
Edited by CamGTP
I did. I purchased HP tuners. All I did for the time being was enable the sensor, the corresponding MIL codes and filled in the alcohol afr table. I didn't want to do anything outside of OEM parameters. This was purely to show what the power gains on the stock GM tune is with ethanol.
"I can easily just post a few tunes I've made here." What do you mean by this?
What I mean is that I can post tune files I have made for myself and other people that you can use if you want or at least see what I do to them.
They will have improved changes over the OEM settings. For things like power enrichment, commanded air fuel ratio on gasoline and ethanol. Minor timing changes and engine torque mngt changes.
If that is a 6 speed truck (probably not because it's a denali) I know how to make them shift and act way better than stock.
Post your current tune here if you want too. I'm curious what it looks like compared to the other 2015 file I have.
I would be very interested in looking those over if you don't mind. I do in fact have the 6l80 trans due to having a Denali with the 5.3. I will post my stock file as well as the file that i made the changes to run Ethanol.
I appreciating you helping me with this!
Alec Sierra stock tune no ccm no changes.hpt Alec Sierra stock tune + E85.hpt
This is a 2015 Silverado 5.3/6L80e combo. It should be almost exactly the same as your truck calibration wise, when it was stock.
I went through and just updated this file and changes a few more things that I normally do now. Feel free to use the changes and ask questions about it. The engine stuff and transmission changes will make it drive like a different truck. Remember that you are just copying the changes and not writing my file to your truck as that won't work. You can open my file with yours using the compare feature to see what is changed over your file.
Just note that if you do try out the transmission changes you will have to reset the adaptive learning with the scanner on HP Tuners. After the new tune is flashed in and "before" you start the truck you do this:
Flash tune, open VCM scanner, connect to truck, start a new scan, click the special vehicle functions and find the transmission tab. There should be two boxes for the trans adapts that say preset and reset. Click reset first and then preset. Now start the truck. Simple as that, now it will learn the new settings and the first few shifts will be a little clunky but that is normal.
2015 Silverado. test.hpt
Edited by CamGTP
  • Like 3
If anyone else is considering this, cold starts now have a VERY extended cranking time. I'm looking into it. I'll update if I figure it out. Otherwise all is good. I made the adjustments from the tune shared above and that shaved another tenth in the quarter mile. The truck just feels nicer to drive.
Anything under like 45-50 degrees and it does take an extra second or two of cranking time to start. I never messed with it.
  • 3 weeks later...
By accident, I did a search on my Diablo i3 tuner and found it has a 'Flex fuel' tune in addition to the 87, 91 and 93 octane gas tunes.  So, I filled with Ethanol twice (currently, about 65% ethanol per my Diablo sampler) and tuned it for Flex.  I added a slightly firmer shift (trans is too sloppy and I'm always pressing harder to push it along and now happier since the new tune... I still press the go pedal but for better reasons) and ensured the DOD/AFM is OFF.  Overall, no noticeable change other than the better shifting.  But, it is early and I hope to enjoy it regardless.
NOTE:  I'm not concerned with mileage as I am WFH since March 2020 due to the 'lockdown' and my once-weekly 1-hour drive each way (beer and wings with my buds) is my one long trip I get to enjoy listening to the flowmaster Force II exhaust note.
I am tuning now for enjoyment.  Also, I am looking seriously at potential for delete of DOD/AFM due to my 70K mileage... a separate thread/topic.
Edited by TedH
Interesting you see / feel no real difference. About a week ago I was chatting up a guy in a 2500 while getting e85 and he agreed that his bone stock truck feels like a completely different vehicle when he runs e85!
I tried E-85 for about a month. Like 10 tanks. The only thing that changed was the fuel economy. But I never asked it to do anything more than I asked of it running 87 E-10. Cost per mile was higher in my area of purchase. No joy there. It started the same. Idled the same. Responded the same to the pedal......zero difference in DTD driving.
I can count on one hand the number of times I've had that truck matted in 150,000 miles. 4% power difference at the crank at WOT and at 5,300 rpm I'm not going to notice in daily driving.
I put a 91 octane tune on my truck via the FashPaq as well as updating my  tire size.
I've got it into a 1 MPH difference from actual speed via GPS.
My mileage from 10 or so is now showing about 12.
Today, I reset one of the trip monitors on a daily drive and got 15.
Sure, 93 Octane costs a lot more, but, with a tune, there is a benefit.
This truck runs better than ever before even on these stupid 35 inch tires! 😺
I’ve never driven a car with e85, they dont offer it in my area.
but I would think the e85 changes ignition and fuel timing. I would think that would give you a boost in the low end too. Maybe it only changes the open loop tables? But that doesn’t make that much sense either.
hmm
Yeah, the grunt off the line and throttle response is like driving a different vehicle. It's amazing how different it is just by switching fuels.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
