It's only $1,400 for the computer swap, credits and the tuning device through HP Tuners. It also does require the use of a dealer tool to do a VATS reset too, which would cost more money.
For that money and voiding your warranty, it's not worth it right now.
Don’t think it would be no 4K buy a used ecm from ebay if your 2019+ it’s a e90 on the 5.3 & 6.2 and send it to hptuners
what camgtp said above it’s a lot of $ but in my opinion $ well spent I like access to my stuff lol. One thing I forgot is I already own hptuners pro so it would be another expense for you but camgtp broke it down for you.
Edited by bjr2020 6.2
11 hours ago, Grumpy Bear said:
That is caused by a ridiculously low idle speed. Tune it. Even 50 rpm helps.
Yep. I tuned mine to be 100 RPMs higher at startup and 50 at idle.
FlashPaq F5 tuner.
2 hours ago, Robby James said:
Isn't it not tuneable until I drop the 4k to get ecu swap?
Yea, see I missed that as you posted on the 2014-2019 forum. :uhoh:
  • Sad 1
FlashPaq F5 tuner.
Got rid of the shakes too didn't it? 😉
To be fair, I never had that, I just wanted to have the idle a bit up as it did make a difference on starting off HP feel
at 35 percent i am usually around 5k miles depending on how much towing i do. sometimes it is around 4.5 k. how does raising the idle effect the tranny when you shift from park to drive
It really doesn't change anything. I notice no change and I have mine at 700rpm in park for faster winter warm up's
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   3 Members, 0 Anonymous, 732 Guests (See full list)
