Hello
I have installed a new crate engine and all new parts under the hood no exceptions.
I installed a holley 502-9 670 cfm TBI and a spacer. My problem is the throttle is sticking only when the truck is running I have to blip the pedal to get it to un stuck. When the truck isn't running it doesn't stick what's so ever.
Any thoughts or suggestions?
Thanks
3 hours ago, Skero said:
Hello
Thanks
Try a stronger return spring. The obvious question I was going to ask I’ll pass on.
Just seems weird that it would work fine while it's not running but as soon as it's running that's when it sticks. I was thinking vaccum but I've checked everywhere and no leaks.
So what changes between not running and running? Intake manifold vacuum. It would be sucking the butterflies down into the throat with more suction. I'm not familiar with that throttle body but look for some kind of adjustment for the rod holding the butterflies. You might then have to change the idle somehow.
Well the problem is the intake manifold but not vaccum related it's an aftermarket holley intake and the throttle body sits further away from the the accelerator and cruise control cables. They don't have adjustments so I will have to try and bend the bracket forward or something along them lines.
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
