I have a 15 Yukon Denali (6.2) with a magnuson supercharger and about 100k miles. I have been chasing a Cylinder 5 misfire for a while now. It’s very odd because it only misfires at idle, off idle it runs perfectly. We’ve gone through all of the usual suspects: plug/wire/coil, injector, spring, pushrod, nada. So at this point the only thing left is a bad lifter and/or damaged cam lobe.... unless someone has a different suggestion??
So, if I really HAVE to replace the cam I’m curious what others are going with. Above all else, I don’t want to sacrifice drivability. In the LS world, doing an LS9 cam on supercharged applications gave good results and drivability. Is that a thing for the LTs? Can I just toss an LT4 cam in? I did some searching but didn’t see a lot of cam talk in this forum. Open to ideas and suggestions.
I would go get one of the stage 3 supercharger cams off TXSpeed or get a custom grind.
stock cams work pretty good with boost, stage 3 might be too agressive for street and lead to other wear issues on the valve train, your better off with factory parts for reliability
nah stage 3 on a 6.2 is fine. Especially with a blower. You are upgrading all the lifters and valve springs anyways just don't be a cheapskate and buy eBay junk.
If you are too nervous for a stage three get a stage 2. I am just hear to tell you that a stage 3 would not sacrifice drivability in a larger cube engine. The rule of thumb for these "stages" is that all of them are based off of a 5.3. The stage 2 on a 5.3 is like a stage 1 on a 6.0 or larger. Stage 3 is a stage 2 and so on.
You'll want to get with brian tooley and brain storm to come up with a cam that's easy on the valve train. Likely a cam motion cam core. This will ultimately give you what your looking for. He will go over your current engine spec and provide you a solution. He's been in this cam design game for a couple decades
https://briantooleyracing.com/
is it more lift or just longer duration on those cams vs oem cam?
like PMoore states in his video, the LT5 makes like 750hp with the same lift as the oem  5.3 cam, so its probaly all durration for durability
Edited by pokismoki
longer duration and more lift. stock cams are normally .500 but the low lift aftermarket normally is about .550. I'd have to take a look at the stock cam.
Saying that though .550 is pretty easy on valve springs and a lot of stock springs can handle it. LS6 springs are cheap and good to use.
Lift doesn't define durability as long as you have the valvetrain to match. :D
after you get the cam and valvetrail installed, the two biggest issues you will wrestle with is feeding fuel and then stopping the high powered Pig.
I just did a trans tune and activated Power enrichment and that was getting the truck to the point of overwhelming the brakes. i really cant drive it in the city stop and go.
Feeding fuel isn't that big of a problem with only a cam. Especially if he is already SC'd I can imagine that he has injectors plentiful enough as well as the fuel pump to go along with it. On a stock engine of his vintage it is not an issue at all, back in the NBS days yeah you probably needed some 8.1L injectors but not really anymore.
I suggest you change your brakes or your driving style. PE and a trans tune is not going to overwhelm them lol. I'm on a stock 1999 brake system with my cammed LQ4. The stock brakes suck ass but they aren't any worse lol
What do you drive?
What do you drive?
2016 k2 LT 1500, the problem with our trucks brakes is they are overly front biased, truck potentially has lots of braking power if it used the rear rotors correctly
Have you pulled the valve covers and check the valve springs.  L86 I known for breaking valve springs!!!!  I speack from experiance.
But If you want a good cam.  I have had a TSP 5.3 stage 2 218/226 32% over in my L86 for almost 30K miles now.  The plan was to be boosted by now but.  I just haven't pulled the trigger.  To many other toys.  It runs hard for a full bolt-on NA truck.
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 836 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
