2014 Silverado K1500 5.3L 6 speed auto . Not sure what is going on , transmission shudders when shifting into higher gear at low rpm's . I turn tow/haul on and it eliminates the problem 98% of the time . Can this 4l80E(??) be reprogrammed to hold shift longer without tow/haul on ? The truck had oversized tires on it , took it from 285's to 275's , better ride . Truck runs smooth , the V-8 to V-4 mode works , just doesn't like not being in the tow mode !
Yes, with a tune you can make the transmission shift speeds different.
You could make 6th gear happen at 80mph if someone truly wanted to do that. I suggest a tune to make changes to the shift mph settings and to stop the torque converter from locking in gears 2, 3 and 4 and only allow it to lock in 5th and 6th gear.
tech3 can perform a relearn and a purge, also install trans upgrade files from GM's database. but no adjustability, get yourself the HPtuners system and stop F'n around : )
The HPtuner system seems very complicated , there are many accessories involved and monies to be spent to understand and use one properly . Not my gig . I will find a tranny shop that does use that system though and have them reset my Chevy . Thanks for that input .
Thanks for the advise . This is a used truck and I am starting to think someone has already "tuned" the transmission , will get GM to reset to factory specs and start over .
  • 1 year later...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
