Long travel beast for example:
I want to know more about this truck.  Any links to more information?
Coming from a Fully built Long Travel Tacoma (I know I know, its a smaller truck, but still), you're not gonna get trophy truck performance off of anything bolt on. I've eyeballed the 'Long Travel' kits from Dirt King and Baja Kits a few times, but building any long travel truck is a money pit and a headache lol. Thanks for posting pics btw, I've have the BDS 4" kit in my cart for about a year now debating on getting it.
If you're still stock in the rear, that's definitely your problem running trails. Stock shocks aren't going to perform anywhere close to bolt on Foxes, and as someone else said, putting some weight in the bed helps.
I was looking into trying to mix and match the Camburg performance leafs with whatever lift it balances out to match the BDS 4" lift block, plus adding some sort of storage situation in the rear to add weight for a better ride.
Another thing to think about-
TUNING.
I don't know what stock tune the Foxes come with from BDS, but I'd be willing to bet they aren't tuned perfectly for offroad usage, (usually a medium between street ride and offroad usage), so its going to ride semi well on road and offroad, but you can't have both. My Tacoma felt amazing at about 60MPH+ across trails/dunes/Whups, but rode like absolute garbage under that speed on road or dirt. And that was with about $15k per axle.
Anyhoo, I would say go with the Fox rears, look into a performance leaf pack and lose the block....or the smallest block you can find combined with the best leaf pack, AND throw some weight in the back. (Funny story- my first Tacoma I had I put some big ass 4" lift springs in the rear and drove around with an XXXL Home depot storage container filled with big ass rocks and sand, probably about 200-300lbs just to settle the leaves a bit, rode like a dream with that box in there lol). Even my LT truck always rode smoother when I put about 200lbs in the bed.
Feel free to msg me and we can talk shock tuning and such. I'm not expert on the matter, but it took quite a while to get triple bypasses tuned up to the point where I was able to hit 80MPH across a mile long whup section at the beach.
TUNING.
Thanks for the reply, some good info for sure. Sounds like a badass Tacoma! I love Toyotas too, no ****** talking here
I did order a custom Deaver leaf pack that that is built off of their M27 kit and it will eliminate the 4" rear block. I think this will help a lot compared to stock with an overload spring.
The hard part I'm having now is finding a shock that has enough length to make use of the additional down travel gained from the leaf pack.
I spoke with Accutune (who have great customer service btw) and the longest Fox 2.5 DSC they make for our trucks would bolt on, but it would be maxed out and wouldn't have any down travel.
Unfortunately Fox universal custom shocks won't fit due to some weird fitment issues they had with the reservoirs.
The only off the shelf shock I have found that will fit are the Rough Country Vertex shocks which will handle up to 7.5" of lift. They are adjustable and have a remote reservoirs, but I wouldn't expect the performance or reliability to compared to Fox or King of course.
  • 5 months later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
