Hi everyone,
The other day someone dented and scratched my passenger bed and drove off. The driver's side has rust, not terrible yet, in the wheel well. I live in PA so we get road salt.
I definitely want to repair the dent, but then the rust would need to be addressed at some point. Not sure how long it takes for the rust to spread and get real bad.
Worth it to just replace the bed with a takeoff or fix the rust while it is contained and also fix the dent?
Thanks
The question really is what its like behind the outer skin.  If the flanges are shot where the inner and outer of the box meet at the wheel well, you'd be looking at not only a new outer skin but the wheel well metal itself.
If the rust is just in the wheel well and not too bad as you said here's a "maybe" option.  I'd do this only on an old truck I wanted to keep.  But it might work on newer trucks too.  Like I said....this is a "maybe" option, to keep from going way overboard with new this and that.  Get the wheel off so you can get into the well easily.  If the rust is not all the way through with a hole showing you could use an  electric sander or hand sanding block to get rid of that rust, and get it all.  Don't leave any to spread.  It might be that you end up going all the way through the metal to get it all....I don't know, since I can't see it.  If you do, bondo works wonders at filling up places like that, and its sandable.  I've used Bondo Wood Filler with very good results.  But, of course, they make the body filler they're known for. About $11 at Walmart.  If you end up using that I'd then get some of that I would spray the sanded area good with 3 coats of cold galvanizing.  Follow instructions.  Then I'd get some of that rubberized spray-on bed liner and spray the inside of the well to keep (hopefully) further rust away.  Its just an idea.
all the panels and repair parts are readily available aftermarket, it depends on your skill level how far you go. maybe get the parts and take it to body shop?
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
