1 minute ago, Supreme Pizza said:
   Right. Now I remember. They are also a little shorter than the lower TTY bolts, right?
Shorter and smaller.
normal system pressure is 16- 18 psi and you should be able to test at 20-22 psi without damaging anything thats not ready to fail anyway
Looks like only two of the top bolts were a little loose (around 45degrees to get to torque.  They were adjacent though.  Being in the center it likely screwed up my torque pattern.  I’m going to sleep on it.  Thanks for the help everyone.
I know I said I was done for the night, but I thought I’d pull the valve covers.  I was expecting some sludge due to the symptoms.  Quite a bit of sludge and some coolant present in the recesses where the head bolts go on the drivers side.  The recesses also look like the castec TSB which was what I was trying to avoid by getting new heads.  Passenger side looks normal, except for the expected sludge.  I think I have a cracked head.  I will sleep on that!05274D65-CD19-4AC8-8540-12FE4EEFC3D9.jpeg.beeb28eead2eac351a3cebbb1b6dc61b.jpeg
that was my guess. you need to change the oil asap and crank it over to get the contaminated oil off the bearings. antifreeze will destroy the bearings
I hope it’s not too late, I put about 200 or so miles on it since the initial repair.
I think the engine will be fine.
I would just add the head gasket sealer, and drive it. Then change the oil, and drive it some more. Then maybe change the oil again.
The sealer will fix a cracked head.
Nothing big; I decided to replace the head since it’s under warranty.  The company is sending another out.  Going to drop the oil pan and clean as much sludge out as I can.  I will follow up with everyone.  I don’t see much happening for the next couple days.
sounds like you got it under control, how did you determine which head it was? sludgy stuff will accumulate on the side with the pcv no matter which side leaks
Inspected both, one had the areas near the head bolts that looked steam cleaned.  It’s in an earlier pic I posted.  The other looked normal.  There’s a few pics on the web showing this as GM had a TSB on this issue.  Incidentally, I replaced my heads during this job to avoid that as they were the casting with the TSB.  The head that cracked wasn’t.  I’ll post a pic of the head that I believe to not be cracked in a second.
This is the head that I believe to be good.  Look under the rocker assy at the head bolt recess and compare it to the previous pic.  In the previous pic you can see the same area looks steam cleaned
Coolant goes through those little cracks as steam, some goes in the block and gets vented out of exhaust via PVC system.  Some mixes with coolant and is distributed as sludge.  As such, oil level does not significantly rise that fast.  Also dexcool isn't as easy to see in oil as other formulas.  That’s what’ I’ve read and I’m finding it to be true.  All those new parts now compromised!!
Very hard crack to deal with as it only become evident when hot and/or under a lot of pressure.  My cooling system held 15psi shop air for an hour.
Even my leak down test at100psi did not show that issue.
But, as much as I like working on machines, I’m not an auto mechanic and could be wrong.
not doubting you I was just curious . I haven't seen the tsb but I can see it in the pix. you must be a very patient person, I would be livid. have you inquired about labor reimbursement where you bought the heads? thats 1 advantage to dealing with a local independant parts store, they will usually go to bat for you when you have an issue like this
No big updates.  I received the replacement head today so I went ahead and finished pulling the old one.  I did not see any thing that looked like a coolant run on top of or under the head gasket.  I did drain the leg side of the block before I started; that was a help, but it opens up a channel for leaks.  If anyone one wants to see any pics of the job, please let me know.  I’m by posts pic of the block plug removed.
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
