My silverado from 2011 has now run 100000 mls. I changed the spark plugs 300 miles ago. Now i looked at the plugs again. One of the plugs, the one from cylinder 6 is black. All the others are clean. The engine doesn't have any problems. No oil consumption absolutely nothing it hasn't always done. Does anyone have any idea why the plug from cylinder 6 looks so completely different? I am grateful for any hints
possibly partialy clogged injector. try a couple tanks of non ethanol fuel with Techron injector cleaner
 Cylinders 1,4,6,7 are AFM cylinders, so that may be a reason.
You could bore scope a few cylinders to see if they look the same. But I kinda agree, toss some seafoam in the tank or a fuel system cleaner to see if it helps. Obviously move that dirty plug to a different cylinder.
thanks for the food for thought .
Should the AFM be the cause, are there no alarms on the dashboard?
Will a failed cylinder not be displayed to me?
Look at the center electrode porcelin, its not straight and square like the others. I would replace that plug with a new one put it back in number six and run it for a while and then check again. We have been getting alot of defective AC delco parts right out of the box lately. Possibly a boot leg knock off counterfit  part.
So many counterfeit 41-110s that GM released new part number.  Chicom knockoffs have been wrecking engines left and right, don't use them unless bought from dealer, Summit, RockAuto, etc.  Lots of Chicom plugs sold on Amazon and ebay.
Now i have tried the old spark plugs (50.000mls) i have cleaned them and drove 100mls. everything looks fine now. no black colour on spark plug no 6. Now i will buy again some new spark plugs. It looks like one of the new ones was junk. thank you, BR Josef
I'm curious as to why you pulled the plugs in the first place after changing them. did u have a misfire?
the reason is as follows. I had recently removed the spark plugs after 50000 miles. ( as a routine, no trouble) In doing so, i realized that the color of one of the 8 spark plugs was very light. There were also some small white spots on it. However, i was not sure from which cylinder i had removed it. I wanted to see how the new spark plugs looked after 300 miles. I found this one black spark plug. This was the beginning of my confusion. But now i see that everything is fine. It is probably only one of the new plugs that is not quite right. I am replacing it now.
When I have an issues on one cylinder - I check the compression on that cylinder. (100lbs minimum for it to fire reliably). Then I swap the fuel injector, spark plug, spark plug wire, and ignition coil to another cylinder. If the problem follows the parts, then you know its either fuel, or spark. So then you move the injector again to the next cylinder, and see of the problems stays with the ignition parts or follows the fuel injector. Its just as effective as "throwing" new parts at the truck, but its free and much less time consuming. I tracked it down to being a bad spark plug and/or a bad spark plug wire on a PT Cruiser the other day (check engine light, accompanied by a P0303). I replaced them both just to save time. I had both on hand, so why bother testing any further. Then I cleared the codes, and it was good to go. Swapping injectors and coils around sounds hard to some people, but its not. You only need a couple basic hand tools and 10 or 15 minutes of time.
Edited by Supreme Pizza
thank you supreme pizza. that is a very good strategy. I will follow if i have got some trouble like this in future. best regards Josef
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
