2007.5 2500hd OEM trailer brakes are not working correctly. A few details:
1. It is truck-side. I hooked up a different truck to my trailer, and the brakes worked.
2. I replaced the trailer brake module and the relay located by the back tire and also checked the fuses.
3. The trailer brakes work if I start the truck while holding the brake. Then as long as I continue to press the brake, they work.
4. Once I let go of the brakes for more than 3 seconds, a notification comes on the dash saying "Service Trailer Brake System." If I press the brakes after this point, the trailer brakes do not work.
Any help would be appreciated.
Thanks!
Edited by Nate Carlson
Giving more info
You need to indicate if you have a "classic" '07 (NBS) or the mid-year upgrade 07.5 model (NNBS), as they are pretty different trucks.
I dont know enough about the details of how the system works to be able to assist you.  If nobody else does, perhaps sign up for a subscription to the full-service manual for your truck and go through it's braking section.
  • Nate Carlson changed the title to 2007.5 2500HD Trailer Brakes
Check the grounds on the brakes. some controllers are more sensitive.
 The grounds are usually a metal magnetic disc that moves and tightens the arms/shoes.
These, and the area they ride on can get rustly
