Hi,
  So I have a 2015 Silverado 1500. Recently had a key fob get lost and have a replacement but need to program it. I can't seem to get into programming it with my Modis Edge scan tool and really don't feel like dealing with the dealer just to redo the fobs. Has anyone come up with a way to program these fobs without going to the dealer? I know my Modis could do the fobs on my friends 17 so wasn't sure why I can't get to it on mine.
Thank you
Edit to add:  I have seen Dorman sells something that plugs into the OBD port and comes with a fob but haven't been able to find the tool separately.
Edited by John Fleming
I've programmed a new fob through the Autosync device, found here:
(it ain't cheap - plus they're back ordered, currently. If all you'll ever need is a key fob programmed, just go to the dealer)
https://www.btdieselworks.com/products/2015-2018-autosync
I looked at that when I did the android auto upgrade and cluster from WAMS. Looks like some really neat features but nothing I need for that price. Especially just to do a fob.  Thanks for your response.  I'm hoping it's something simple I can jump a couple pins in the OBD port to activate or something similar.
I'm not sure if that's doable.
I think you'll need to unlock the BCM to get it done  - as the dealer would do or the Autosync would.
And that is where the Autosync becomes extra money - ya gotta pay extra to unlock the BCM and HMI.
Same as the FlashPaq F5 for the ECU.
In my experience, it's all been worth it.
But, then, I like to play around with modding things to make my truck a little different than others.
Most won't notice except me.
You're best off visiting a dealer for a FOB program if you're not interested in the ability to further mod your truck with the aforementioned devices..
Edited by MikeBMW
I somehow lost my key and key fob for my 2014. I had a spare key however. I bought a blank key online and new fob and took them to a locksmith. He cut me a new key and programmed the key and fob to my truck. I think I had about $75.00 in the locksmith and the cost of the blank key which wasn't much. Hope this helps someone. Dealers are expensive!
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
