Hello so I’m coming here because I’m at a loss. So purchased an 08 suburban with the 6.0 had 180k on it. Engine ran smooth no issues back in April. Since then the lifters were replaced pistons/rings and all new gaskets/seals. First the lifters ran beautifully after getting it back for about a week or two then started smoking. Took back to the garage they went over everything they did and then did another oil change. Two weeks later smoking again. After all that took it to a Chevy dealer and they came to the conclusion that the oil rings were shot. So at that point I just had them put new pistons in as well. Didn’t make it home and went into limp mode 16 miles into the drive. Got it home they didn’t hook everything up. Did it myself but something still didn’t seem right. Motor was all but completely rebuilt on both bottom and top end. Took it back with video of what I found and they went back over “everything”. I didn’t mention this was all done under warranty. So the warranty company made them check everything over while the motor was apart. Vehicle still smokes (not nearly as bad) and now has acquired this horrible bottom end tick/knock. Not 2500 miles later. Any help would be appreciated.
  • Sad 1
What kind of smoke Brian and have you determined which cylinder it is coming from?  Have you put a compression gauge on that or any of the other cylinders?
It is SOP to replace the lifter trays and VLOM anytime the lifters are replaced on the AFM system.  Did they use OE trays?  Aftermarket trays fail almost immediately but that's an aside and not sure your problems begin with that.
When the pistons were out of the block, were the cylinders checked for roundness, measured for size and honed?
Thanks for the response. I was told by garage that they put oem trays in when they put new lifters in. When they put new pistons besides me asking they did tell me that they measure and check all the cylinders. Wether they did hone it or not I have no idea. All this work was done by my local Chevy department. Not if Dan of them just by how they responded to most of my questions. I haven’t determined which cylinder or do a compression check yet. Smoke is heavy white from what I could tell.
White smoke is coolant.  Seems like it is getting into the combustion chamber.  Now the question is where is it coming from?  Cracked head?  Head gasket leak?  Throttle body leak?
If Chevy did the work, it ought to be under warranty.
Garage came back and said it’s piston slap 🙄. Which to me does not sound anything like it. No issues before. Reason I replaced the pistons was it was smoking and the rings wore worn. Figured just to replace the pistons as well.
Could you possibly record a video, post it to youtube and link it here for us to see and listen to?
Now since this I have gotten it back from the garage sounding worse yet. Stating that it’s just piston slap and is fine to drive. That it will not cause anymore damage 😂
  • Sad 1
Thanks Brian.  Did you happen to pull the torque converter inspection cover and see if the bolts were loose?
Did you say in the video that the oil leaking was new?  Have you checked the level?
I'm no expert on all LS engine noises so let's get some folks to have a listen and get their input.
@doubeleive@Grumpy Bear@Black02Silverado@shakenfake
Brian, bump this thread around 10 am or so and more folks will get to see it as well.
Piston slap happens first thing on start up and then goes away.  That sounds more like a lifter is bad.  Could have gotten a bad lifter, it happens. But the smoking is an issue.  That shouldn't happen.  Sounds like they did a bad job of installing the pistons.  More than likely they didn't hone the cylinders since it is smoking.  I would take it back and let them know it isn't right and you want it fixed.  Be nice, I know which will be hard to do but more will get done being nice but firm than demanding with an attitude.
:dunno:
I'd be guessing and that isn't useful.
Sorry.
here is my take on it, if there is white smoke and lifter/valve tap, this "might" mean there is water getting in.
has the coolant level dropped at all? even a very small leak will cause a problem, even if it is burning it off and not causing a milkshake.
if so what is happening is the coolant is mixing with the oil in a particular cylinder/area and this makes the oil not as efficient in that area and you end up with "noise" in that area.
again if this is the case you could pull the valve covers off and see where it is happening it will usually present it's self visibly.
you can also look under-inside the oil filler cap (it has a cavity area when you flip it over) and see if there is any white or green snot looking material and/or look down in the filler hole with a flashlight and look for the same snot. some people say a little material there is normal but I have never found this to be the case with a good running engine.
if it is not loosing any coolant at all then yes it could just be a noisy lifter and likely won't cause any immediate damage, my 03 made the same noise on & off for years and drover perfectly fine, I of course did not have warranty on it nor any engine work done.
the bottom line is like mentioned above take it back and say hey this isn't right, be nice usually that gets you nice in return. even if you didn't have to pay out of pocket yourself they got paid and it should be addressed as long as it is still within the warranty period. a simple "it will be fine" is not acceptable in this case.
Not always. Many engines can have the piston slap stay even after it's warmed up. Pretty common with the GM 3.1 and 3.4 engines. I bought a 2003 Malibu with 88,000 miles for $600 with engine noise and front end damage. I tore the whole top end apart, inspected all the parts, new lifters and threw it back together. Start it up and has the same exact noise it did before. It's all piston slap in that engine even when fully warm. The oil is completely clean too, no metal shine or glitter. I just stopped caring and it's had about 1,000 miles put on it since.
For the OP, it's still kinda tough to nail down exactly where it's coming from. It does sound half the speed of the crank though.
Edited by CamGTP
Okay so I did check the oil. Nothing abnormal. Coolant seems like it hasn’t leaked either. I haven’t pulled the the cover to check the bolts yet. No when I say it got worse it loud enough to hear knocking while driving. Plus seams to have lose of power if you do drive it. Oil leaks are new. The motor was always dry from when we had bought it. It has been 8 months. All the seals and gaskets for motor are new. Honestly only things not replaced internally are oil pump, crank, rods and rockers. Oil pressure at idle is showing less than 20 now also. You hear it all the time cold start warmed up driving. Tomorrow Ill try to take a another video. Thanks to all that have responded.
Heard back from the new gm dealership today. First thing he pointed out was that cylinder 3 had misfired 7384 times! and others but no so much. His master mechanic was running more diagnostics after hours to try and get to the bottom of what is going on with the motor, but had confirmed that there is some major issues going on with it.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,659 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
