Hi,
I'm working on a friend's 2007 GMC Sierra 4WD, and it is not starting and not cranking. I brought the Snapon Solus Edge home from work and ran codes. U0140 and I can't talk the BCM at all. Fuses on the LH side of the dash are good for feeding the BCM.
I keep hearing about a fusible link? (Sorry - I'm not real familiar with GM stuff). I've read that it supplies the BCM.
Can someone give me a clue where that would be on this truck?
Thanks much from a newbie.
--Bill
A schematic (Haynes books carry a representative edition of wire schematics) can sometimes show the GENERAL location of components, think of the top of the page as the front of the vehicle. Some auto parts houses have component location info on their websites, I have asked dealer service depts. but they usu. don't know off the top of their heads, usu. a VISIT will make them feel like that have to go look it up, dealer parts guys can some times help. "ALL DATA" will most likely have it. A lot of public libraries have ALL DATA on line. GM has several manuals for it's vehicles, there is a general one, a transmission one, one for other major systems, etc. What I'm trying to say is not all the info or complete info can always be found in one book that's in your hand, if you have access to a GM CD you might find it all there. Sometimes you can find CDs for older vehicles on Ebay... I'd go to your local public library.
1.svg2.svg3.svgHope this helps.
if you have no com with the bcm check power and ground at the bcm.
make sure you use a good test light and not a multimeter to check for power and ground. I recommend checking power and ground using a head light bulb. The head light bulb should light up nice and bright but if it doesn't you may have a high resistance wire. 9/10 times if you have one module down and have power and ground present at the module, the module is bad.
Edited by Kyle Ross
8 hours ago, Kyle Ross said:
let me know if your able too see the wiring diagrams i uploaded
I am - thank you very much. I've got them downloaded, opened and printed. Looks very helpful. I'm going to get back on this over the weekend. Cheers!
Thanks - I've got access to Mitchell's at work - I hardly ever use it since I'm usually in other things, but you've reminded me it's there - I'll check it tomorrow.
So I checked at the connectors on the BCM today, and testing from ground on the connector to power on the same connector, I had battery voltage. This is on connectors X2, X3 and X4. Based on this I'm calling power and ground good to the BCM, and thinking that the BCM has gone bad.
It's weird - the sequence of events that led up to this:
1- Check engine light was on - unknown code - he doesn't have a scan tool.
2- My friend was trying to clear it by disconnecting the battery. He disconnected the positive lead of the battery and left it off for 4-5 days (had other things going on and forgot about it).
3- He comes back and re-attaches the positive lead, and noticed the interior lights are not on with the door open.
4- Tries to start the truck and zero. No click, no starter, nothing. Plus, now he's got multiple warnings in the instrument cluster to service different systems and things that are offline.
All this from just leaving the positive cable of the battery off for a few days. Kind of blows me away that a BCM could (apparently) go bad just by being powered down for a few days. Truck has about 150k miles on it and is in pretty good shape and has been maintained well.
So do you all agree that it sounds like the BCM is bad?
Any ideas as to why the BCM woulda quit, after reading the sequence of events that led up to this? Opinions?
thanks much,
Bill
Control modules need no excuse to quit, they got a pretty good union! Stray volts shot though the circuits, (a wire rubbed bare next to a ground) loose ground some place (there is a chapter in GM manuals for ground locations), a weather proof plug that's no longer weather proof. Silly stuff like that. Once upon a time modules were programmed to go bad after certain time/mileage point were passed...I don't know if that's true or not any more. Some times that stuff just goes,  resistor gets weak, a capacitor opens, a diode stops working; it's usually some thing like that, you know, a $1.00 thingy goes bad in a module and it costs $239.99 to get a new one/you have to turn in the old one. It gets "overhauled" for $50.00 and the next guy pays another $239.99 for it....Life goes on...
Edited by dna9656
spelling
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • Wawa and Meijer here have ethanol free (88 & 89) I use for my mower and lawn equipment.  Its not much more than reg.  I paid $3.29 a few weeks ago.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • NewDude, thank you for the suggestions!    I did follow up and the dealer indicates he has an open CX case and is working with DPAC (Dealer Parts Assistance Center).   Per the dealer, GM has had a quality spill and is not providing an update for when a replacement engine will be available.
