I've been having a hard time finding any good information on this package that my dealership automatically added to my contract for $995.  They talked about it during signing, but only because I mentioned I planned on having the truck detailed and ceramic coated once I got it.  The finance manager acted like that wasn't needed because "we do that already for all new cars".  One, making it sound like what they do is a true ceramic coating (which I know there is no way they could do in an hour of dealership prepping a new vehicle; and two that it was included and not an extra charge.
As I stated, I am planning on taking my new truck to a local detailer and having them do a full paint correction and buff before applying a true Ceramic coating; but I cannot find any specific details on what the spray-on ceramic coating that is supposedly applied as part of this deal is.  Also, if all they are doing is Scotch guarding the leather seats; I really don't think that is worth almost $1000.
Does anyone have any experience with the Paint and Fabric Defense offered by Allstate?  Is there really any value provided by the coverage or is it really just snake oil to put $$ in the dealers pockets?
I don't, but I'm sure it is just an "insurance" policy. They probably do spray some junk on the seats but is of little value.
I didn’t believe in that stuff until I got two vehicles with it already done. My wife’s Genesis was a CPO when we bought it. 11 years later it still looks good, inside and out. The CRV had it done it’s a 15. Six total cross country trips no bug marks. Not saying I’d pay for it to be done, just saying it works. I’m for letting them wear out and look bad, so I can get another one in a reasonable time frame.
My dealership charges almost 3k for that "package" and swears that they use a ceramic coating on the paint... Although, I think its bs
Yeah...I'm still waiting on delivery of my truck (a week late now and it's sitting in a lot 50 miles north of me).  I keep going back and forth in my head on whether $995 is worth it or not.  I'm also fairly sure that the actual "protection" they apply is absolute garbage (no way in heck a quality paint or fabric protection can be properly applied in under 2 hours); but it MIGHT still be worth the 5 year "insurance" side of it for if there are any tears or issues with the interior leather.  Always hate the idea of paying for insurance type coverages (paint and fabric defense, extended warranty, etc) as you may never need them; but many times if you do need to use them, they can prove worth every penny.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
