Normal is good.
Every 6.0 I've owned or been in run 35-40psi after cold start idle down, hot idle 25-30psi.
GM minimum spec is 6psi for every 1000rpm, so as long as you are over 6psi at 1000rpm, its fine.
Edited by newdude
  • Like 3
2 hours ago, Grumpy Bear said:
What's the question?
Or are you just saying your motor has normal oil pressure?
:dunno:
Yea, without punctuation, hard to tell if it is a question, or statment😬
  • Thanks 1
